Old 10-16-2011, 08:19 PM   #1
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
SR 5 Lug, S13 Diff Cover w/ Cooling Fins, 28mm Rear Sway, HKS Hotpipe, Auto Belts, LCAs
Updated Oct, 28 2011 10:26am
Located:Oceanside and Orange County
Clean S13 Differential Cover w/ Cooling Fins $35
s13 240sx Brand New Yamato Garage Rear Sway bar 28mmOne on Left, Just sway bar, No Bushings(You can use Tanabe rear bushings, theyre $20) $70
Sr20det Coolant Temperature Sub Harness w/ Broken Clip $10 each
Stock SR20DET Intake Manifold Comes with both Intake Manifold gaskets in good condition, and whatever in picture, No IACV, No Throttle Body $40
Stock s13 Coupe Automatic Brown Seat Belt System w/ Ecu Rails, Belts minus driver belt, Ecu $40
s13 Rear Lower Control Arms Boots not in great shape $20
Regular Straight 2" Stock Hotpipe SR $10
Sr20det Coolant Hard Linew/rubber hoses $10
Stock SR20DET Thermostat $5
Front s13 240sx Stock 24mm Sway Bar. $15
Anything in these pictures $5
Set of 12x1.5 Tuner Lug Nuts w/ Key $20
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
