Old 10-06-2011, 04:43 PM   #1
TheWayItGoes909
TheWayItGoes909's Avatar
TheWayItGoes909 is an unknown quantity at this point
Talking Stock S13 SR20det And Other Parts
EVERYTHING IS SOLD AS IS. PM FOR QUESTIONS. LOCAL PICKUP PREFERRED. WILL SHIP
75A FUSE $15 obo each.
Uploaded with ImageShack.us
240sx S13 STOCK RADIATOR CAP $5 shipped
S13 SOHC EVAPORATOR $40
S13 SOHC CONDENSER $40
SOLD...
180SX REDTOP SR20DET AC COMPRESSOR I NEVER RAN IT. AS IS $30
STOCK S13 SR20DET INTAKE COLD PIPE WORKED GREAT $30
STOCK 1990 S13 240sx FUEL PUMP WAS WORKING GOOD BEFORE REMOVING.$40
STOCK S13 SOHC KA24E ECU $40
STOCK SR20DET REDTOP BOV $10
SR20DET TRANNY SENSOR (NOT KA24) FROM REDTOP SR20DET $15
SR20DET REDTOP STOCK EXHAUST CAM WORKED FINE BEFORE PULLED $40
1st gen Apexi SAFC $120 shipped
Never Installed.
(1st Gen) complete with wire harness. Basically what the S-AFC does is alter the voltage the ECU receives from the MAF/MAP sensor. This causes the air/fuel mixture to either go leaner (-) or richer (+).You can adjust in increments of 2%.You can fine-tune the mixture at different RPM points (800rpm, 2400rpm, 4000rpm, 5600rpm, 7200rpm).
Please consult a professional for installation. [/B]
[FONT=Arial Black][SIZE=-1][COLOR=Black]Size: 12cm x 13cm, *1 inch = 25.4 mm = 2.54 cm.
[COLOR=Black]
Not Pictured...
S13 REDTOP SR20DET OIL PICKUP STRAINER WORKED FINE... $30
Z32 26mm Rotors been sitting in garage, lil dusty...$50
94-97 Accord Type R style lip White BNIB In packaging comes with mounting Hardware... $60
BEE*r RHD 60mm Triple Gauge Pod holder *RARE**RARE*RARE**... $220 Shipped
Bee-R FRP BR Meter Gauge Panel S13 S14 S15 R32 R33 JZA80 FD3S
TheWayItGoes909 is offline   Reply With Quote
Old 10-07-2011, 11:09 AM   #2
Fitzroy240sx
Fitzroy240sx is an unknown quantity at this point
Do u have a stock sr20det ecu for a s13
Fitzroy240sx is offline   Reply With Quote
Old 10-07-2011, 11:13 AM   #3
Fitzroy240sx
Smile Ecu
Old 10-07-2011, 02:16 PM   #4
myc013
myc013 is an unknown quantity at this point
are the rotors 4 or 5 lug
myc013 is offline   Reply With Quote
Old 10-07-2011, 06:04 PM   #5
TheWayItGoes909
Stock Redtop 62 ECu has been Sold...
The Rotors are stock Z32 26mm 5lug. Come pick em up! Please make sure they fit your calipers.
Thanks.
Old 10-10-2011, 05:13 PM   #6
TheWayItGoes909
Bump to the top...
