Old 02-23-2012, 07:55 AM   #1
titangts
titangts is an unknown quantity at this point
FS: (1)2jzgte harness for s14. extended, cheap!!!
SOLD SOLD SOLD
~~Length of harness is nearly 10 Feet from tip to tip.~~
~~Length of main body from pig tail to where it branches off is 5 feet!!~~
This is THE harness that came out of my 1jz s14. The harness itself is in excellent condition. all clips look great. I personally never got to even start my engine but the harness was used by a previous person.
has soldered in individual resistor boxes so you can BIG injectors or USDM 550cc, or WHATEVER.. the JDM harness's do not have this stock.
The harness Pig tales were actually converted to 2jzgte pigtales. The reason for this is (1.) 2jz ecus are MUCH easier to find if you need to replace the ecu...(2).. most important reason for doing this.. no one makes a standalone or "plug in play" EMS for the 1jzgte harness. with this harness you can plug it straight in your 1jzgte engine and then buy any haltec, AEM or Greddy unit to tune with if you are going big WHP.
This harness will work with 1jz or 2jz. but you have to use a 2jz ECU
PICS:
titangts is offline   Reply With Quote
