Old 12-15-2003, 08:59 AM   #1
phatkorean
phatkorean is an unknown quantity at this point
s13 Driver's side power window doesn't work
I have a 1991 240sx se and my driver's side window doesn't work. I connected a working motor, which was tested on the passenger side, and the motor didn't work. There is no noise coming from the motor at all. I did notice that the wire coming from the window motor connects to a little black box in the door. This black box makes a ticking sound when I press the up or down buttons of the power window. The driver's side controls for the passenger side window works just fine. Anyone have any ideas? And what is that little black box? Thanks.
phatkorean is offline   Reply With Quote
Old 12-15-2003, 11:41 AM   #2
misnomer
misnomer's Avatar
The black box is a relay. If it's clicking, it *generally* means it is still working OK. Do you have any way to check for power at the wires? Multimeter, test light, etc. . . If there is power at the wires coming from the relay, you can rule that out as the problem. The motor may not be making any noise because the regulator (the frame/cables, gearbox that everything runs on) might be jammed. Does the window go down? When mine went out, it would go down, but I'd have to pull it up by hand.
If it seems you are getting nothing out of the motor, I'd check to make sure the relay is getting power, use a testlight or voltmeter at the wires that go in to the relay.
Old 12-15-2003, 12:53 PM   #3
phatkorean
I don't have a real way to test the wires. I tried out the new motor (it came with the car when I bought it) and that didn't work. I didn't actually connect the motor up to everything, just the wires. I did this one the passenger side and the motor worked. I just held the motor in my hand and the gear would just turn and turn. When I tried it on the drivers side it nothing happened at all. If that ticking black box is a relay and it's getting power (obviously from the ticks) then perhaps there is a bad connection somewhere. Eitherway, you're right, I need to test the wires and see if any power is coming out of that relay. Thanks.
Old 12-15-2003, 07:16 PM   #4
Idratherbsidewayz
Idratherbsidewayz is an unknown quantity at this point
Thats fucking odd to see someone with the exact same problem as i have, hmm ill check mine and if i figure it out, ill post up the info...
Idratherbsidewayz is offline   Reply With Quote
Old 12-15-2003, 09:29 PM   #5
kickertu
kickertu is a well-known jackass
i had the same problem, and it ticked too.. i replaced it anyway.. and voila.. problem solved..
just cause it clicks doest mean it makes contact
kickertu is offline   Reply With Quote
Old 12-16-2003, 10:08 AM   #6
S13Nissan240SX
S13Nissan240SX's Avatar
S13Nissan240SX is an unknown quantity at this point
Send a message via Yahoo to S13Nissan240SX
Yeah, I've had that problem too. If you call up your Nissan parts dealer they'll probaly call the relay ("black box") the "Power window Amp". At least that's what mine calls it. The clicking doesn't mean that it's working properly in this case. If you switch that out, it'll probably work. It fixed my problem.
Best wishes,
Matt
S13Nissan240SX is offline   Reply With Quote
Old 12-16-2003, 12:24 PM   #7
phatkorean
Holy crap! I called a few places and the part (called a Window Regulator part # H072137F16) cost about $140!! I need to find a junk yard or something.
Old 12-16-2003, 02:46 PM   #8
kickertu
i have sh!t brown interior, so i went to the j/y and took all the black interior out of a car... the relay "jumped" into a box that was marked for parts.... it was the weirdest thing...
nothin like free.... im sure they will only charge you like $5.00 if anything at all.. most places cant inventory such items
Old 12-17-2003, 06:31 AM   #9
phatkorean
Haha, yeah you have to watch out for those jumping car parts! With any luck I'll find a junk yard with the parts I'm looking for.
Old 12-17-2003, 07:38 AM   #10
jean-seb
jean-seb is an unknown quantity at this point
Thumbs up
its sure if not the relay because is the ignition relay. its often you power window amp.
jean-seb is offline   Reply With Quote
