Old 11-13-2011, 09:34 PM   #1
240nessx
240nessx's Avatar
240nessx is an unknown quantity at this point
Heater Core Control Valve Delete?
Is it possible to remove this control valve, and block off that pinhole where the rod comes out?
240nessx is offline   Reply With Quote
Old 11-13-2011, 10:24 PM   #2
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
yes it is possible, but the heater core will always be hot, that would suck in the summer or during hot days.
rcdad123 is offline   Reply With Quote
Old 11-14-2011, 09:56 AM   #3
240nessx
240nessx's Avatar
i dont care if its hot during the summer, i just want heat during the winter.
Old 11-14-2011, 11:42 AM   #4
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
why would you want to remove that? You still have heat with it as long as its open
jacobs13 is offline   Reply With Quote
Old 11-14-2011, 07:49 PM   #5
240nessx
240nessx's Avatar
i dont have heat and im pretty sure its stuck closed, so by removing it, if i get heat i know thats my problem
Old 11-14-2011, 09:09 PM   #6
jedi03
try disconnecting ur heater hoses an run water through it...if flows freely will be open...if not stuck closed
Old 11-15-2011, 12:30 PM   #7
jacobs13
jacobs13's Avatar
Did you not take that pic? Looks open to me. Just take it off and clean it out and out some lub on the hinge and put it back in so it works properly
Old 11-15-2011, 01:44 PM   #8
240nessx
240nessx's Avatar
Lol no I found that on google...ill try lubing it and cleaning it thanks.
Old 11-17-2011, 06:15 AM   #9
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
yea I need to fix mine too... let me know if that works for you
Old 11-21-2011, 07:56 AM   #10
240nessx
240nessx's Avatar
I disconnected the heater hoses and ran water through both sides. No blockage either way, so its not the control valve.i also disconnected the top and lower heater hose while the car was running and coolant was running through the heater core so its not air locked. Now I'm really stumped. You can hear the blend door moving and hear the sound difference. But the temp stays the same.
Old 11-21-2011, 08:35 PM   #11
jedi03
if you have electric fans install controller that will turn them off so your motor can heat up
Old 11-22-2011, 06:11 PM   #12
240nessx
240nessx's Avatar
i have a clutch fan...but i held that stopped to heat it up...and still no heat
Old 11-23-2011, 07:43 PM   #13
jedi03
leave ur rad cap off while running the car...see if it bubbles as it runs...if so you got a bad headgasket..if not you may have block in ur lines somewhere
