Old 11-29-2011, 06:15 PM   #1
grandma's koukis
grandma's koukis is an unknown quantity at this point
holy tire wear batman!
So here's the scoop. I put brand new tires on my front wheels about a month ago, they've only got a thousand or so so miles on them. While working on my car today I notices on the iner side of the tread the wire is already showing! What gives?! I run 0 camber on the front. I have tein he's, stock rods. I know it probably needs an alignment, but any ideas of what is causing this? Too much toe in or out?
Any ideas/suggestions appreciated
grandma's koukis is offline   Reply With Quote
Old 11-29-2011, 06:18 PM   #2
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
You answer your question..needs alignment ..
S-Nation S13 is offline   Reply With Quote
Old 11-29-2011, 06:34 PM   #3
franklin93zx
franklin93zx is an unknown quantity at this point
give your car back to grandma
franklin93zx is offline   Reply With Quote
Old 11-29-2011, 06:52 PM   #4
OneviaLove
OneviaLove is an unknown quantity at this point
Lol well played
OneviaLove is offline   Reply With Quote
Old 11-29-2011, 06:55 PM   #5
jdmae86
jdmae86 will become famous soon enoughjdmae86 will become famous soon enoughjdmae86 will become famous soon enoughjdmae86 will become famous soon enoughjdmae86 will become famous soon enough
camber doesnt kill tires as much as toe... I put 40k miles on my last set of tires running -2 degrees on the front.
jdmae86 is offline   Reply With Quote
Old 11-29-2011, 06:57 PM   #6
AE_Racer
AE_Racer is an unknown quantity at this point
toe-in/out kills tires faster than camber. get an alignment.
http://tougestars.net
AE_Racer is offline   Reply With Quote
Old 11-29-2011, 07:05 PM   #7
J40sx
J40sx's Avatar
J40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choices
alignment is key
dying is only living, dying to live
J40sx is offline   Reply With Quote
Old 11-29-2011, 07:08 PM   #8
UG-T
UG-T is an unknown quantity at this point
that extreme wear on the inside edges usuall indicate too much toe on the front there (toe out). Get new tires and align asap.
Car should even handle alot better as well
post up a before and after alignment spec sheet when you get it done
UG-T is offline   Reply With Quote
Old 11-29-2011, 07:10 PM   #9
heavenboundkevin
heavenboundkevin's Avatar
heavenboundkevin is an unknown quantity at this point
hey bro, maybe you should get an alignment
Originally Posted by rat240 View Post
sick bro .... hella jdm foshow i love haters
heavenboundkevin is offline   Reply With Quote
Old 11-29-2011, 07:14 PM   #10
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
Toe. Doesn't matter in/out. Will kill tires regardless. Get it aligned, and leave it alone.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 11-29-2011, 09:35 PM   #11
Wheelchair
Wheelchair's Avatar
Wheelchair is an unknown quantity at this point
buy new tires...
...if that don't work... get a proper alignment.
Wheelchair is offline   Reply With Quote
Old 11-29-2011, 09:43 PM   #12
John Hammond
John Hammond's Avatar
John Hammond is an unknown quantity at this point
you sir, need to spare some expenses on an alignment.
spared no expenses
John Hammond is offline   Reply With Quote
Old 11-29-2011, 11:40 PM   #13
Jared0934
Jared0934's Avatar
Jared0934 is an unknown quantity at this point
To sum up this post, your alignment is out of wack and need to adjust toe. Camber doesn't effect wear, it only wears one side of the tires more-so than the others due to more weight/less contact surface. Take it to firestone or something, like $30 bucks for a normal alignment. Thread over, OP happy.
1993 240sx "Sil680"
Jared0934 is offline   Reply With Quote
Old 11-30-2011, 12:59 AM   #14
grandma's koukis
Thanks, as well as thank you to all who replied.
Username is a play on grandma's cookies, and yes I do realize kouki is pronounced koh_key.
Old 11-30-2011, 02:22 AM   #15
ayuaddict
ayuaddict's Avatar
1 degree of toe will kill tires faster than 10 degrees of camber.
Old 11-30-2011, 11:23 AM   #16
Bushido
Bushido's Avatar
you run zero camber up front?
wtf?
Old 11-30-2011, 11:38 AM   #17
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
It's koo-key.
omgRWDgoodness! is offline   Reply With Quote
Old 11-30-2011, 11:51 AM   #18
CMFD13coupe
CMFD13coupe is an unknown quantity at this point
I figured this would be a good place to ask...
Does camber in the rear wear your tires a lot faster than camber in the front?
Im thinking so because power is being exerted on the rear but then again you have the engine weight on the front.
If I wanted to run 0-1degree in rear and 2-4degree in front would that much camber kill my front tires?
CMFD13coupe is offline   Reply With Quote
Old 11-30-2011, 12:51 PM   #19
OBEEWON
OBEEWON's Avatar
You need more sticker bomb.
Old 11-30-2011, 03:55 PM   #20
Bushido
Bushido's Avatar
Originally Posted by omgRWDgoodness! View Post
It's koo-key.
No it isn't. That's just what every uninformed person in Florida thinks.
Old 11-30-2011, 05:17 PM   #21
DenkiMan!
DenkiMan!'s Avatar
DenkiMan! is an unknown quantity at this point
you can get lifetime alignments at firestone for $170 i think....lifetime meaning as long as you have the car
Originally Posted by PSI240SX View Post
Although the 97 Maxima was aesthetical perfection, I thought the factory body lines could use some expert "tweaking" so I ran it into a couple of things at low speed.
Looking for another pair of 17x9 Veilside Andrew Racing V's
DenkiMan! is offline   Reply With Quote
Old 11-30-2011, 05:19 PM   #22
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
its your tires...keep buying new tires fix it right up!
joshchewuhh is offline   Reply With Quote
Old 11-30-2011, 05:22 PM   #23
yomisiu
yomisiu's Avatar
yomisiu is making a name for him/her selfyomisiu is making a name for him/her selfyomisiu is making a name for him/her self
so its koh-key?
wtf
im out.
peace.
yomisiu is offline   Reply With Quote
Old 11-30-2011, 05:40 PM   #24
t0nyakapb
t0nyakapb's Avatar
t0nyakapb is an unknown quantity at this point
really? anything that can void this?
Vehicle wraps S14/S13 matte 3M colors= $ 1,500
Hood=230 Trunk =190
t0nyakapb is offline   Reply With Quote
Old 11-30-2011, 05:48 PM   #25
omgRWDgoodness!
Trader Rating: (48)
Originally Posted by yomisiu View Post
so its koh-key?
wtf
im out.
peace.
lol, x2. This coming from someone who lives in BFE North Florida.
Old 11-30-2011, 05:52 PM   #26
waxball88
waxball88 is an unknown quantity at this point
Yeah i too did not know until Bushido told me IRL. I was shocked, but how would i have known better? lol
waxball88 is offline   Reply With Quote
Old 11-30-2011, 07:23 PM   #27
AE_Racer
koh-key pho sho!
<--informed bfe north florida redneck.
Old 11-30-2011, 07:32 PM   #28
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Pics or it didn't happen
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 11-30-2011, 07:44 PM   #29
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
i think he ment to post in one of the honda forums
da_crew10 is offline   Reply With Quote
Old 11-30-2011, 09:38 PM   #30
Bushido
Bushido's Avatar
http://tts.imtranslator.net/Iic6
heh, i took a japanese class one summer.
and i'm from ft. lauderdale... everyone in florida says kooky, north and south.
