Old 11-18-2011, 01:58 AM   #1
hatch
hatch is an unknown quantity at this point
Dying over night
11-16-2011, 10:44 PM *
im getting sick of unpluggin my battery. I bought my 240 about 3 years ago ( rb20) and i have had a problem with it dying over night since I first got it. It Hasnt been really buggin me til now. I bought a new battery 4 months ago cuz the old one is bad and had my alternator tested to and it was good. i did a multi meter test and i was getting a reading of .40 amps with the car off. so i took my test light and hooked it up to the neg. post and neg wire and the light turned on. its dim i cant get the light to go off no matter what i do. i have unplugged my ecu, pulled every fuse under the dash and in the engine bay. i also unplugged the alternator, starter, ignition switch, fuel pump, injector harness and coil pack harness. even with al this stuff unplugged the light is still on but my multi meter only reading .25 amps...
what am i missing cuz this is starting to give me a head ache?
also i touched my injector wires where they connect to the ecu with my test light and all of them are getting power with the car off andd the key out. are they supposed to get constant power?
hatch is offline   Reply With Quote
Old 11-18-2011, 04:01 AM   #2
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
What else is connected to the battery? And have u done any modifications to the haness? I would disconnect the plugs going into the ecu and cabin harness ( white clip) and check if u got power? If u do then something is getting constant power from the engine harness.. Maybe your lower harness? Check if u have any non oem wiring. Pm Jeff Jordan he probably has a better solution for pin pointing the problem
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 11-18-2011, 04:12 AM   #3
Lostinthegame
Lostinthegame is an unknown quantity at this point
I had the same problem. Ma Motorsports fixed it a month ago. Make sure that you check the fuse panel under the dash. They said that they had to redue some of the wires. Good Luck!
Lostinthegame is offline   Reply With Quote
Old 11-21-2011, 12:19 PM   #4
hatch
ok so found the issue area... its the 2 green relays near the ecu. i got 2 new ones to see if it fixes the problem but it doesnt. if i unplug one or both then the light goes off but once i put both back in the light cuts on. what do these 2 relays go to??? heres a pic of them.
http://t1.gstatic.com/images?q=tbn:A...gTQwcaniINdSJN
Old 11-21-2011, 12:33 PM   #5
Darren
Darren's Avatar
Darren is an unknown quantity at this point
Have you checked out all your grounds?
if the grounds are inadequate, then the electrical system won't work as intended...
something to check out, anyway
Darren is offline   Reply With Quote
Old 11-21-2011, 12:35 PM   #6
hatch
ill check them again but anyone else have an idea of what these go to?
Old 11-21-2011, 02:43 PM   #7
OoAtreyuloO
OoAtreyuloO's Avatar
OoAtreyuloO is an unknown quantity at this point
Going through the same problem my fuses under the dash and alternator and starter all pull batt. Even when i disconect he ground
OoAtreyuloO is offline   Reply With Quote
Old 11-21-2011, 02:44 PM   #8
OoAtreyuloO
Woops typo when i pull the key*
Old 11-26-2011, 06:30 PM   #9
Rukis
Rukis is an unknown quantity at this point
im having same problem dont know what it is so any thing yall did to fix let me know i want to fix mine
Rukis is offline   Reply With Quote
Old 11-26-2011, 08:41 PM   #10
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
you obviously have a current draw somewhere, start pulling fuses and see what circuit is draining your battery
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 11-26-2011, 08:56 PM   #11
delado
delado's Avatar
delado is an unknown quantity at this point
I had this exact same problem. I had bought the cheapest battery (new) because my old one gave out. Well, this new cheap battery worked awesome till I left it over night and my car wouldn't start in the morning. Thought is was something staying on but it turned out this cheapo battery didn't even have enough cranking power so it would get drained easily just from starting. So i returned it, got a yellow top optima, and now I can leave my lights on all night and no issues.
delado is offline   Reply With Quote
