Old 12-29-2003, 07:29 PM   #1
Evil S14
Evil S14 is an unknown quantity at this point
Send a message via AIM to Evil S14
Talking Fresh off the dyno :)
finally dynoed my car
97 S14
stock KA24DE 97k miles
.4 bar (~6 psi)
370cc injectors
T3/To4E 60 trim .63 ar exhaust
Revhard manifold
Stock ECU
Hacked MAFS
3inch downpipe into apexi n1 dual
no cat
PWR FMIC
the a/f surprised the hell out of me considering there is NO fuel management
*image exceeds forum limit*
-Moderation
Evil S14 is offline   Reply With Quote
Old 12-29-2003, 07:38 PM   #2
SR20DETpwr
SR20DETpwr is an unknown quantity at this point
Where did you get your car dynoed at? I live in the indianapolis area and will be looking for a place to dyno my car after the winter months to see how much hp all of my mods have given me.
SR20DETpwr is offline   Reply With Quote
Old 12-29-2003, 07:44 PM   #3
Evil S14
it was at one of my friends shops called Modern Speed Labs off of Pendleton Pike
Im holding a dyno day there in the spring
do you know who i am, i drive the black Kouki S14 from the south side
-Moderation
Old 12-29-2003, 08:43 PM   #4
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
Sweeet, sounds good. Maybe I'll be able to hop the dyno with my 130ish rwhp.
thelinja is offline   Reply With Quote
Old 12-29-2003, 08:45 PM   #5
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Good pull there.
zero.counter is offline   Reply With Quote
Old 12-29-2003, 09:04 PM   #6
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
very nice...
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 12-30-2003, 03:06 AM   #7
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
Looks like your turbo selection is giving you power on the spot, good choice. Do you feel any lag with it whatsoever?
-Juan
240Stilo is offline   Reply With Quote
Old 12-30-2003, 09:17 AM   #8
cdlong
i'm not used to reading A/F charts, but isn't your car running way lean? it is pretty smooth though. i could sure go for an extra 100 wheel HP
cdlong is offline   Reply With Quote
Old 12-30-2003, 09:56 AM   #9
sykikchimp
WOW addicted
sykikchimp's Avatar
13:1 isn't so bad, and it's only there for about 1000rpm.. a little leaner than most like to go on turbo, but not crazy. What's important is that it's at 12:1 at the higher rpms where detonation is more prone
What ID piping did you use for the MAF?
What is your base timing?
Have you done a compression test? if so what kind of numbers?
good numbers!
Old 12-30-2003, 11:04 AM   #10
Evil S14
good numbers!
the ID was ~2.75", i didnt use a mic so i dont know exactly, base timing was at 17 degrees, and i did a compression test w ahile back, i beleive the readings were a solid 186 across the board,
-Moderation
Old 12-30-2003, 11:05 AM   #11
Evil S14
and if you look closely it never actually hits 13:1, but about 12.8 to 12.9
and yes there is lag, but its not crazy
-Moderation
Old 12-30-2003, 11:46 AM   #12
fastpace
fastpace is an unknown quantity at this point
good numbers despite your fuel management. I can't wait to I get my turbo project on the go.
Do you plan to add more fuel management components or just run it like it is?
life is what you make of it!!!!
"well, I go out, I do the practice, I think about it and I concentrate on one small thing I can change that will have an effect. I make that change then I go out and drive to my maximum." -Ayrton Senna
fastpace is offline   Reply With Quote
Old 12-30-2003, 12:04 PM   #13
Evil S14
im goin e manage and 50 lb msd top feeds, i wanna be onne of the few people who break 300 rwhp on stock internals
-Moderation
Old 12-30-2003, 02:37 PM   #14
SR20DETpwr
I think I've seen your car downtown a time or two. Do you know Jeff w/ the JDM H22 powered accord? Have you seen my buddy's 92 prelude w/ H22 (NSX orange pearl & cf hood) - used to have a N2O kit, but he sold it to Jeff. Hit me up when you plan on having the dyno session - [email protected] (my car should be running by then).
Old 12-30-2003, 03:38 PM   #15
Evil S14
jeff is a goofy bastard, he told me he was goin turbo h22
-Moderation
Old 12-30-2003, 05:52 PM   #16
SR20DETpwr
No, he's not goin to turbo it. I think the money situation fell through, but I have no idea if that was the case or not. He does have all the connections if ya need somethin though. He hooked me up with the guy I bought my front clip off of and the same guy is wiring it up for only $200 along w/ helping me out with other misc. items.
Old 12-30-2003, 09:44 PM   #17
cdlong
13:1 isn't so bad, and it's only there for about 1000rpm.. a little leaner than most like to go on turbo, but not crazy. What's important is that it's at 12:1 at the higher rpms where detonation is more prone!
my bad, i was looking at the chart backwards.
