Old 01-01-2012, 03:32 PM   #1
champwho
champwho is making his/her stupidity well-knownchampwho is making his/her stupidity well-knownchampwho is making his/her stupidity well-knownchampwho is making his/her stupidity well-known
how much should i boost?
got a sr20 redtop brian crowr valve springs and retainers and the rest of the motor is basically stock and got a tomei arms b7652 740 injectors 3 inch piping blotz fmic how much should i boost on this setup i wana know if i can be aroun d 300hp and if its safe or not
champwho is offline   Reply With Quote
Old 01-01-2012, 03:34 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Here what you need.
A good tune from a reliable tuner.
Get a power fc or aem or something similar.
Or at least a rom tune.
Old 01-01-2012, 03:36 PM   #3
champwho
i have a power fc sorry forgot to mention that
Old 01-01-2012, 03:54 PM   #4
brndck
brndck's Avatar
then make an appointment at driftspeed, and get that shit handled.
shouldn't be a problem to hit 300hp with that turbo and injectors.
Old 01-01-2012, 07:50 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
How much you can boost will depend on the tune...
CLICK HERE!!!
Old 01-01-2012, 08:04 PM   #6
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
Yeah, someone with a dyno will help you. It will be easier if you have a stand alone. Get a Vipec if you want to do some crazy stuff.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 01-02-2012, 12:13 AM   #7
champwho
dont want anything crazy just 300hp would be good for me maybe even more cause i wanna daily it still....how much does driftspeed charge?
Old 01-02-2012, 12:43 AM   #8
chineseb0i
chineseb0i's Avatar
chineseb0i is an unknown quantity at this point
Send a message via AIM to chineseb0i
what turbo you have? T25 or T28? Usually for both turbos it's recommended you not boost more than 15 psi since the turbo doesn't run efficiently pass that point. 260 rear wheel hp is what you should be able to achieve.
89 240sx Coupe
chineseb0i is offline   Reply With Quote
Old 01-02-2012, 12:52 AM   #9
KoukiDrifter240
KoukiDrifter240's Avatar
KoukiDrifter240 is an unknown quantity at this point
advice keep low boost and be happy u will get hungry for more but u will eventually break it happens to the best of us lol
farewell kouki!
KoukiDrifter240 is offline   Reply With Quote
Old 01-02-2012, 01:12 AM   #10
colombianbryan
colombianbryan's Avatar
colombianbryan is an unknown quantity at this point
with that turbo/setup you have there im certain you will hit 300whp easily with a good tune!
I love drifting into curbs and guardrails
colombianbryan is offline   Reply With Quote
Old 01-02-2012, 01:42 AM   #11
champwho
well i though that 15psi for stock turbos... i dont have a stock turbo i have a pretty decent turbo i heard my turbo can run with teh gt28 turbos so not to sure but thats what i heard and naw i dont get throttle happy but to have that much power will be great and im sure i wont step on it cause gas isnt cheap ahah
Old 01-04-2012, 12:31 PM   #12
Kingtal0n
Kingtal0n's Avatar
The general rule is you dont go over 18psi on 93 octane pump gas with any sr20 and any turbocharger unless specific modifications have been done to eliminate this general rule.
at 18psi, with 95%VE at 7,000rpm, and an efficient turbocharger/intercooler, most SR20's will see between 370-400RWHP.
In your OEM redtop internal "shoes" I would stick to 15psi or less, probably 12psi max, to assure under 300rwhp so you don't spit a piston ring- assuming the compressor actually flows 32+lbs/min.
Old 01-20-2012, 03:45 PM   #13
RyanKuly180sx
RyanKuly180sx is an unknown quantity at this point
My Red Top is running at 11lbs and its plenty.(Swapped in a t2871r during the swap) Still enough to get a little sideways around corners in the city...
Specs say up to 15lbs stock, but I haven't tried it..
The black tops are made with Denser Aluminum and shit, so I would only be pushing the boost passed 12psi on one of those. Especially if your mostly stock.
RyanKuly180sx is offline   Reply With Quote
Old 01-20-2012, 03:57 PM   #14
cotbu
cotbu's Avatar
You ever just wanna punch someone in the face!
Anyway the sleeves are steel!
Sent from my Highly Tuned Vibrant!
Old 01-21-2012, 07:38 PM   #15
champwho
ok so im at 14/ or 15 psi my boost guage doesnt mark it that well.. and i have a powerfc and fc commander bc cams the 264 i believe and a tomei arms b7652 and i dont know how to adjust the boost because the wastegate isnt adjustable
Old 01-21-2012, 07:50 PM   #16
Sileighty_85
Sileighty_85's Avatar
What the hell are you talking about? Are you one of those kids that think Engines are rated by boost and not HP?
Ummm a boost controller.....
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-21-2012, 08:50 PM   #17
champwho
wow now i feel dumb i new that all along sometimes i dont think straight ahah
blitz, boost, sr20, tomei
