Old 02-12-2012, 11:49 AM   #1
CC200SX
CC200SX's Avatar
CC200SX will become famous soon enoughCC200SX will become famous soon enoughCC200SX will become famous soon enough
What readings should i expect? Ca18DET EGT`s setup
Just finished my EGT´S SETUP install, on the CA18DET, with 4 "K" type thermocouplers egt sensors.
They are to be connected to a 4 channel multi gauge digital, and for a healthy ca18det, and good and safe afr`s, what readings should i expect to read?
CC200SX is offline   Reply With Quote
Old 02-12-2012, 01:18 PM   #2
Croustibat
Nice setup, but i am not sure it will work correctly. These sensors makes average measurements, and the exhaust gases come by pulses. You may be reading 50°C less than what you really have, this is the reason why people only use one, where the exhaust tubes join.
Anyway reading are whatever the car is mapped for ... Turbos have their own limit, most of the time it is around 900°C continuous, 950°C on spike. See the manufacturer for that. If the temp is low, the turbo will spool poorly (it works by exchanging heat), so you can ask your tuner to dial higher temps in . Just remember it is cold out there, so temps wont be that high.
