Old 01-14-2004, 08:00 AM   #1
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
Attention Audioheads:Wiring up a stiffening capacitor
I have a system in my '91 FB,and it sounds really nice,I have a Bazooka amp(with Infinity sub), until I get my stiffening cap. wired up I'm running a 4ohms instead of 2 stable,I have it mounted and chargedbut I have no clue how to wire it up,its a Lightning Audio 1 Farad unit with digitial voltmeter...it has two large gold posts,one is marked positive,and the other negative,and has 2 available connections on each post(actually 4,2 front,and 2 side...for more mounting flexibility,but only 2 are usable each post at the same time) and I know that you are supposed to run your power line to it,and from it to your amp while mounting it as close as possible to amp...but wich post do I run my power line into,and wich do I run my power line out of into my amp ? The local audio shops all want $30-45 just to cut the wire that I already have,and run it...
Thanks !
I really need to know!
Ghettokracker71 is offline   Reply With Quote
Old 01-14-2004, 04:19 PM   #2
Ghettokracker71
Come on.......I know SOMEBODY on here knows how the hell to wire one of these things,and it would save me good money I could put into making this thing more of ahonda killer
Old 01-14-2004, 05:11 PM   #3
95auto
95auto is an unknown quantity at this point
you are going to run the capacitor in Parrallel with your existing battery,
run the (+) wire from your battery to the (+) of the capacitor, then from the (+) of the capacitor, to the (+) of the amplifier.
run a ground from the (-) to a GOOD chassis ground.
adam
95auto is offline   Reply With Quote
Old 01-14-2004, 07:23 PM   #4
Ghettokracker71
adam
Very much thank you!
Old 01-14-2004, 10:14 PM   #5
stillmatic
stillmatic's Avatar
stillmatic is on a distinguished road
I hope it's not too late, but make sure you charge the capacitor before you install it. It should come with a charge card or resistor.
The install is just like what auto95 said. However, you can connect the capacitor + and battery + to the amp. The ground wire should be no longer than 18" and use 8 gauge or thicker wires.
stillmatic is offline   Reply With Quote
Old 01-14-2004, 11:14 PM   #6
kandyflip445
kandyflip445's Avatar
Um...did you say it has a digital voltmeter on it? Those only hinder caps and sometimes even make them worthless. The cap would be more effective if it was just a normal cap without the digi readout. Also, it might help if you upgrade your grounds. Your engine ground, alt ground, and your main battery cables. I think I'm forgeting one more but oh well...
My 240 vBgarage
Old 01-15-2004, 12:21 PM   #7
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
yes, charge it! you could run the risk of blowing it up if you don't.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
