Old 01-14-2004, 02:18 PM   #1
kendot240
kendot240 is an unknown quantity at this point
SR sr not running rite searched
OK heres what's going on. I have a red top and I just finished putting tomei cams 270 in 270 ex, rocker arm stoppers, valve springs and 1.2mm head gasket. While the head was off I also did a mile port. Anyway when I start it runs like crap for about five minutes and then just dies. When I pulled the spark plugs out they are wet with gas. So my question is why is my car getting flooded out. i'm pretty sure I have the timing rite, what else could it be??? Somebody please help I've gotta get the car running rite before I go back to school next week!!!!
kendot240 is offline   Reply With Quote
Old 01-14-2004, 03:53 PM   #2
89s132b
89s132b is an unknown quantity at this point
Could be leaking injectors. Pull off the fuel rail (with injectors intact). Turn the key to the "on" position to let the fuel pump prime. Then just check for any leaks.
89s132b is offline   Reply With Quote
Old 01-14-2004, 10:59 PM   #3
kendot240
If I pull the fuel rail off w/injectors intact won't the injectors spray everywhere when I try to start it?
Old 01-14-2004, 11:02 PM   #4
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
no, not until you "START" the motor and the ECU tells the injectors to open. if they spurt/drip, you need to replace the guilty one(s).
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 01-15-2004, 12:16 PM   #5
kendot240
ohh ok I got it. I'll check that
