Old 02-17-2012, 11:05 PM   #1
Dieselcre
Dieselcre is an unknown quantity at this point
Ka24de swap wiring
Ive researched, but im sure someone will say "research it" anyways i had a 95 s14 and the dash burnt up. i know have a 89 s13 shell that i am swapping the dohc engine in. i cant find anywhere that says you can use the 95 ecu and wiring harness. i just need an answer as to if i can use the dohc harness, ecu, and ka24de engine and transmission. or do i need a s13 body harness for the alternator, starter and transmission.
Dieselcre is offline   Reply With Quote
Old 02-18-2012, 02:53 PM   #2
Arsenal240sx
Arsenal240sx is an unknown quantity at this point
Use an s13 ECU and harness.
Edit: The lower harness for the starter and alternator will work. Im doing a 95 KA into an 89 coupe body too.
Arsenal240sx is offline   Reply With Quote
Old 02-19-2012, 12:15 AM   #3
Dieselcre
So use dohc s13 engine harness and ecu. and use the alt harness from the 95? have you swapped it yet?
Old 02-19-2012, 12:30 AM   #4
Arsenal240sx
The S13 sohc alternator plug should work from what Ive read. Ill be doing my swap which is a 95 KA with an S13 harness and ECU as soon as the machine shop gives it back. Lol Also doing a 5spd swap while Im at it. The lower chassis, not transmission harness should work exactly the same and be plug n' play.
Old 02-23-2012, 01:00 PM   #5
xayevier
xayevier is an unknown quantity at this point
I am trying to find this out as well except i am using a 92 engine.
xayevier is offline   Reply With Quote
