Old 03-28-2013, 08:11 AM   #1
trickey1991
trickey1991 is an unknown quantity at this point
R32 Clutch Pedal sucks to floor, then fine
Hey Guys,
I have a 1992 R32 Skyline GTS-T with RB20DET.
When driving sometimes the clutch will suck down to the floor , i pull it back up with my foot and its fine for sometimes 10-20 minutes of in town driving or it can go 2-3 days.
but sometimes it will do it 3-5 times in a 30 min span.
I have replaced the clutch master cylinder and the clutch slave. and the system is properly bled.
what could it be?
92' R32 GTS-T 355whp
trickey1991 is offline   Reply With Quote
Old 03-28-2013, 08:19 AM   #2
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
do you notice any fluid in the car, under the clutch pedal?
Chrischeezer is offline   Reply With Quote
Old 03-28-2013, 08:28 AM   #3
trickey1991
Nope everything is dry
Old 03-28-2013, 09:04 AM   #4
Chrischeezer
did you replace the clutch master and slave for this problem? or another?
Old 03-28-2013, 10:06 AM   #5
trickey1991
Yep replaced both
Old 03-28-2013, 11:47 AM   #6
Chrischeezer
If this thing is falling to the floor like its leaking... chances are... something is leaking...
are you loosing fluid over time?
Old 03-28-2013, 11:56 AM   #7
mnight
mnight's Avatar
mnight is an unknown quantity at this point
Could be your throwout bearing?
mnight is offline   Reply With Quote
Old 03-28-2013, 12:23 PM   #8
trickey1991
no fluid lost/
Old 03-28-2013, 04:30 PM   #9
ultimateirving
ultimateirving's Avatar
Mine does somthing kind of similar, i have only replaced the clutch and slave, MC is next along with a SS braided line.
But try this and tell me if its the same too
"Set you hand on the clutch pedal and barely push, Mine slowly falls all the way to the floor",
as if there is an internal leak somewhere. I cannot find clutch fluid leaking anywhere however. hopefully we can help each other and figure this deal out
Z32 with lq4 swap
Old 03-28-2013, 04:54 PM   #10
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
If pedal is soft. Fluid is escaping/air is getting in. Otherwise if properly bled the pedal will be stuff due to force from pressure plate and pressure built up inside the lines(when depressed).
So fluid is leaking externally. Or internally, past the seal made on either master or slave when put under pressure.
Please anyone chime if this is wrong. But this is my thinking based of my knowledge of hydraulic systems. ESPECIALLY one this simple
Tho I bet u got air in the system. Bleed that thing real good. Those soft lines directly from master to
Slave make it much easier
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 03-29-2013, 06:41 AM   #11
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I cant remember now but does the R32 have the same shitty dampener loop as S-chassis? If it does, is that shit still in there? If it is, it probably still have air in there...
CLICK HERE!!!
Old 03-29-2013, 09:22 AM   #12
trickey1991
Damper is removed, and the pedal is stiff as Shit, it doesn't fall to floor if slightly pushed Hmmmm
