Old 03-11-2012, 04:45 PM   #1
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
how can I fix this?
Broke the two studs for the second mounting point of the steering column...What is the best way to fix this?
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 03-11-2012, 05:01 PM   #2
Dustxking
Dustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of light
If you can drill them out then just get some nut/bolts and bolt the column down.
Dustxking is offline   Reply With Quote
Old 03-11-2012, 05:04 PM   #3
MeanS14
MeanS14 is an unknown quantity at this point
SMH.....you and Raymond with the negro strength!!
MeanS14 is offline   Reply With Quote
Old 03-11-2012, 05:09 PM   #4
i need tires
I looked at that option but they are basically bolts welded to the back side of the bracket.
Was looking at that as a last option honestly lol
Old 03-11-2012, 05:12 PM   #5
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
So you are looking at the easiest option as the last option? What is your first option...ducktape?
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 03-11-2012, 05:12 PM   #6
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
wayi read it, drilling w/ nuts and bolts lookslike the only option??
nismoracingsx is offline   Reply With Quote
Old 03-11-2012, 05:18 PM   #7
i need tires
I obviously dont know what the easiest option is, or what other options I had this is why I asked how can I fix this. If I find out this (drilling out) being my only and best option then I will take action.
Old 03-11-2012, 05:33 PM   #8
Dustxking
If they are welded, i guess if your handy with welding cut them things off and weld on new studs. But i think if you can drill it out big enough you might be ok?
Old 03-12-2012, 12:44 PM   #9
crystalblue99
crystalblue99 is an unknown quantity at this point
i would drill take trip to hardware store new bolt & nut about same size should be on road
crystalblue99 is offline   Reply With Quote
Old 03-12-2012, 06:09 PM   #10
Jus Skott
Jus Skott's Avatar
Jus Skott can only hope to improveJus Skott can only hope to improve
Send a message via AIM to Jus Skott
Looking for yard parts, PM me.
Jus Skott is offline   Reply With Quote
