Old 04-20-2003, 04:01 PM   #1
PAnut240
PAnut240 is an unknown quantity at this point
Send a message via AIM to PAnut240 Send a message via Yahoo to PAnut240
SR Crank knife edging......
Ok, well as some as you know I am finally in the process of rebuilding my SR. Now I am going no-holds-bar on this and everyone keeps telling me to get my Crank Knife Edged. I'm already geting it ballence, I've had that done before but I have no Idea what knife edging does or what they do. If someone can give me some insite I would appreciate it. This may have been asked before but I don't have time to search for it. Thanks and happy driving.
Jim
'89 Fastback  SR20det; Greddy Profec B II boost controller. HKS 262 CAMS. Greddy Radiator,pulleys,oilfilter relocation kit,boost gauge, rockerarm stoppers,intake manifold. Nismo Fuel Press Reg. Ferra duel Valvesprings, ti retainers. East Bear headlight conversion. Type X tail lights. Tien Suspension, Tanabe race exhaust.  GT 16" rims, Walbro high Pressure fuel Pump,  7pt rollcage. HKS BOV. Mandril Exhaust Man. GTR FMIC. BeeR Valve cover. JE Pistons and Eagle Rods.
PAnut240 is offline   Reply With Quote
Old 04-20-2003, 04:07 PM   #2
240racer
240racer's Avatar
240racer is an unknown quantity at this point
all it means is that they turn more material off the crank. The chops end up really sharp like a knife. It's a rotational weight reduction thing and it does make a difference. It's not quite as much weight as a flywheel, but it does make a difference.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 04-20-2003, 05:46 PM   #3
rubbersidedown
rubbersidedown's Avatar
rubbersidedown is an unknown quantity at this point
its also believed that by knife edging it, it will decrease resistance when the crank moves through the oil.
1991 240sx coupe w/ ca18det
Bone stock
Purchased but not installed parts:
HKS adjustable timing gears
Electronic Oil Pressure Guage
Apex'i Multichecker
t3/t04b turbo
Stainless Steel, top mount tubular manifold
ARC bov
450cc injectors
Spearco FMIC
rubbersidedown is offline   Reply With Quote
Old 04-20-2003, 05:54 PM   #4
zspturbo
zspturbo is an unknown quantity at this point
imagine a fat guy swimming. thats what you stock crank is like. now imagine a skinny guy swimming. alot less drag and resistance, right? thats a knife edged crank. the leading edge is sharpened like a knife, so it slices through the oil much better. its really effective on high revving engines.
zspturbo is offline   Reply With Quote
Old 04-20-2003, 10:23 PM   #5
PAnut240
SR
ok thanks guys. That helps me out alot. Guess I'll have to dish out another cuple hundred bucks.lol Later
Jim
Old 01-22-2004, 02:44 PM   #6
fogleroller
fogleroller's Avatar
fogleroller is an unknown quantity at this point
Did you ever get your crank knife edged? Where and how much was it?
thanks (i know this is an old post, but it has the info i need)
fogleroller is offline   Reply With Quote
Old 01-22-2004, 08:42 PM   #7
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
Any good machine shop could do it, last time I checked around my area it was around $100-200.
WilloW is offline   Reply With Quote
Old 01-23-2004, 10:00 AM   #8
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
100-200? are you sure thats right ? Sounds kinda cheap...really
Ghettokracker71 is offline   Reply With Quote
Old 01-23-2004, 10:02 AM   #9
fogleroller
Wow, so you say it's more than that? Is it really worth it? What about just balancing alone? $100-200?
Old 01-23-2004, 10:09 AM   #10
Ghettokracker71
I don't know but it sounds cheap,$100-200...just doesn't sound right to me...but hey,if it is than I'm definitely getting my crank knife-edged soon ! What benefit would it be to get the crank balanced though ? I know that if you take off your stock dampner for aftermarket pulleys it supposedly will eat your crank b/c no balance,....After its balanced...does that not matter ?
I want to have the most efficient componets I can have...so I am definitely planning on running knife-edged,but I don't know what balanced does....I know that the 4G63E Mitsu boys are really big into knife edging...
Old 01-23-2004, 11:47 AM   #11
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
The original idea of knife-edging back in the 70's was to reduce crankcase "windage" by sharpening the leading edge of the counterweights. Aside from the fact that you're lightening the rotating assembly, I think it's doubtful that it provides any benefit. It's pretty common knowledge that the most aerodynamic shape has a blunt leading edge and tapers to a sharp tail...not the exact opposite. Sharpening the trailing edge may actually affect windage...otherwise, it's just weight reduction. But remember, those are counterweights...if you lighten those, you must lighten the rods/pistons.
The more important thing to do is balance the assembly. If it turns out you're counterweights are heavy, it might be a good opportunity to knife-edge. Just make sure it's all balanced when done...a very small amount of metal can have an equivalent weight of several hundred pounds when being subjected to the accelerative forces found inside an engine. Making sure everything is balanced decreases bearing loads and just makes things run smoother and with more reliability.
LanceS13 is offline   Reply With Quote
Old 01-23-2004, 12:19 PM   #12
fogleroller
wow, that is some good info!!! i'll stick to just balancing the crank
Old 01-23-2004, 05:00 PM   #13
WilloW
WilloW's Avatar
This was for a honda motor a while back, I found out that it wasn't neccessary anyway so I never went through with it.
Old 01-23-2004, 06:35 PM   #14
DamnedButDetermined
DamnedButDetermined's Avatar
DamnedButDetermined is an unknown quantity at this point
You are correct about sharpening the trailing edge but as it is now the leading edge of the counterweights are a flast surface. Not aerodynamic at all. Any kind of sharpening or rounding of the leading adge will produce desirable results. You are also correct about balancing the the entire assembly. If you are going this far into an engine rebuilt chances are you are getting aftermarket pistons/rods anyways so they will be light, therefore allowing the reduced weight of the counterweights.
DamnedButDetermined is offline   Reply With Quote
