2 12" JL audio subwoofers in custom box
For sale are two 12" JL Audio 12W3v3-4 subwoofers in a custom enclosure. This was mounted briefly in a G37s and includes wires. The subs are in very good condition, go for almost $200 each new, and sound amazing!
$280 OBO Here are the manufacturer's specs: The JL Audio 12W3v3-4 is rated at 500W RMS and features a single 4 ohm voice coil. This woofer will perform like a well oiled machine. It will provide unbelievable sound reproduction with deep, rich and responsive bass. This woofer sets the standard for what a 12" woofer should look like and more importantly what high-end should sound like. Most other subwoofers will offer power but lack performance or offer performance and lack power. The 12W3v3-4 will not only give you power and unmatched performance but it will also offer many more things which other woofers just can't compete with. JL Audio is all about performance and quality. They manufacture products to meet extremely high standards and anything less than those standards is not good enough to carry the JL Audio name. The W3v3 subwoofer is one of the cleanest, most efficient, and best sounding subwoofers in its class. This series is available in a 6.5", 8", 10", 12", and 13.5" size woofer that can pretty much fit any vehicle size. The W3v3 features a DM Optimized Motor System that provides constant and strong linear excursion that result in reduced distortion and higher bass reproduction. These woofers also feature Elevated Frame Cooling technology that delivers cool air directly to the voice coil of the woofer. This increases power handling and sound quality. The W3v3 series subwoofers offer many more patented technologies that truly make this series stand out above the rest. If you are struggling on a decision, the decision if simple JL Audio, it will never disappoint. 12" Single 4 Ohm W3v3 Series Subwoofer Power Handling: Peak: 1000 watts RMS: 500 watts Recommended Power Range: 100-500 watts Impedance: Single 4 ohms Mineral-filled polypropylene upper cone with a metallic JL Audio medallion logo gives the W3's a whole new, classy and sophisticated look NBR (Nitrile Butadiene Rubber) surround DMA-optimized, long linear excursion capability to virtually eliminate distortion and increase sound output Perform outstanding in compact sealed or ported enclosures DMA (Dynamic Motor Analysis) modeling to deliver unsurpassed dynamic stability and low-distortion operation within intended power range Sensitivity: 87 dB Free Air Resonance (Fs): 28.28 Hz Electrical "Q" (Qes): 0.553 Mechanical "Q" (Qms): 6.936 Total Speaker "Q" (Qts): 0.512 Equivalent Compliance (Vas): 2.729 cu. ft (not recommended box size) Xmax Linear Excursion: 0.510 in. / 13.0 mm Driver Displacement: 0.071 cu. ft. Net weight: 14.50 lbs. ![]()
haha thanks, thought because it fit so nicely in a G37 someone on here might want it.
