Old 03-06-2012, 08:03 PM   #1
jvega
jvega is an unknown quantity at this point
KA s13/14 ka24de needing 91octane+?
Hello, i have a question.
Why would my car (89 240sx W/ 96 ka24de) need the best gas at the pump?
l notice when i put the cheap gas on this car, it tends to "bog" at WOT higher rpm. The other night it shut off completely when i went to the Mountain.
So higher elevation makes it worse with this cheap gas. ?
The engine is stock besides an air intake and filter, and a cat back.
It is using the stock 96 240sx ecu with the complete 96 engine.
Any input would help. Thanks
jvega is offline   Reply With Quote
Old 03-06-2012, 08:10 PM   #2
g00se
g00se's Avatar
g00se is an unknown quantity at this point
I think there is something wrong with your car other than the octane considering it dies.. have you done routine maint?
g00se is offline   Reply With Quote
Old 03-06-2012, 08:39 PM   #3
n8RPS13
n8RPS13's Avatar
Trader Rating: (22)
n8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of light
Feedback Score: 22 reviews
MAF is probably going bad...or TPS sensor, maybe even your IACV.
WASTED I AM!
n8RPS13 is offline   Reply With Quote
Old 03-06-2012, 08:59 PM   #4
jvega
i gave it an oil change like 3 weeks ago and checked/cleaned the spark plugs.
Remember it only 'bogs' with cheap gas at higher rpm and wot. The only time it died was at a higher elevation, about 3k ft up.
Old 03-06-2012, 09:05 PM   #5
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
high octane is the same quality as low octane - it just burns slower.
are you using the correct heat range plugs?
AsleepAltima is offline   Reply With Quote
Old 03-06-2012, 09:16 PM   #6
cdlong
High altitude also lowers the need for octane, hence why where I live (6000 feet), regular is 85, mid is 87, and premium is 89 or 91 depending on the station. I've been putting regular in my car for years with no problems like yours. There's something else wrong with your car.
cdlong is offline   Reply With Quote
Old 03-06-2012, 09:23 PM   #7
jvega
i know the spark plugs are ngk iridium's, i think they are 7's but not sure. I willl check tomorrow.
Old 03-06-2012, 09:33 PM   #8
AsleepAltima
7's are too cold for a stock engine. you should be running 5's. 7's will make the engine sluggish, as you are describing.
Old 03-07-2012, 07:40 PM   #9
jvega
hey i checked the plugs today and they are 5's. Idk what it could be...
Old 03-07-2012, 07:50 PM   #10
AsleepAltima
whats your gap set to?
Old 03-13-2012, 09:56 PM   #11
jvega
Alright, sorry i took a couple days, but the gaps are set to .044 on NGK bkr5eix-11 spark plugs.
Old 03-13-2012, 10:50 PM   #12
AsleepAltima
that sounds about right - i believe its .044-.047 so youre right there. the problem is, neither octane, plugs or gaps will make it completely shut off. have you tried replacing the fuel pump relay? sometimes, when the relays get old, they dont push the same voltage to the fuel pump as they used to and the pump either stops working or works too slowly for the load the engine is asking for. after a drive, pop the hood and see if any of the relays in the fuse box behind the battery are overly hot.
Old 03-30-2012, 03:58 PM   #13
jvega
UPDATE.
It was the fuel pump.. lol..
I changed the fuel pump and it hasn't given me any problems.
