Old 04-14-2012, 09:13 AM   #1
240s4life
240s4life is an unknown quantity at this point
TW S14 Built KA24DET
Item: S14 built KA24DET
Description: Toying with the idea of going VH instead of selling my car, so that means sell my motor first.
Throw out some offers, worst I can say is no. Motor would need to be picked up or I could meet you depending on how far away. no shipping.
Tune on the ECU is currently set up for e85 but it's a programmable ECU, change it back to pump gas and it'll still make pretty close to the same power.
On 20psi running e85 it made 336whp and ~360ft/lbs trq
PM or call/text : 615-939-2975
Currenlty motor is sitting right at 1000 miles on the rebuild so it's still fresh as a fucking daisy. Ready to drop in and get rowdayyyyy.
Motor info:
s14 ka24de
Wiseco 9:1 pistons .020 over stock
Eagle rods
Cleavite 77 main and rod bearings
ARP rod, main, and head studs
New front cover (brand new oil pump)
Ported head with new 3 angle done during rebuild
ISIS 3871r Turbo
Ported intake manifold
Xcessive thermal intake gasket
Xcessive oil pan
ISIS sr lower pan with baffles (holds 6.5qts of oil)
248/232 cams
Titek 550cc injectors
11lb flywheel
Exedy stage 2 clutch with TN clutch 6 puck unsprung clutch disk
Block was honed, has been bored .020 over stock, crank journals line bored, and le block decked during rebuild.
Head has new valve guides and seals, 3 angle valve job, and is ported
Other stuffs that will go with the motor
s13 Nistune ECU with rywire jumper harness (much easier to tune than s14 nistune ECU's)
Z32 Maf
HKS SSQV
Isis bottom mount t2 manifold that's been wrapped with fiberglass wrap.
Isis turbo outlet and 3'' downpipe to 3'' Isis blast pipes.
Isis electronic boost controller
s13 distributor with MSD blaster coil
Walbro 392lph external helper pump
Isis FMIC and all piping
If the price is right i'll throw in the oil pressure, boost, and water temp gauges.
2011-10-26 22.32.23 by mattski_s14, on Flickr
DSC_0203 by mattski_s14, on Flickr
DSC_0024 by mattski_s14, on Flickr
240s4life is offline   Reply With Quote
Old 04-16-2012, 05:15 PM   #2
c_mancuyas8
c_mancuyas8's Avatar
c_mancuyas8 is an unknown quantity at this point
pmed about engine sir
c_mancuyas8 is offline   Reply With Quote
Old 04-16-2012, 06:37 PM   #3
aaronka
aaronka is an unknown quantity at this point
willing to partout s13 ecu with jumper?
aaronka is offline   Reply With Quote
Old 04-16-2012, 11:28 PM   #4
240s4life
no partout, trade pending right now
