Old 02-28-2006, 07:49 PM   #1
Team Rootbeer
Team Rootbeer's Avatar
Team Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really nice
Send a message via AIM to Team Rootbeer
z32 rear rotors the same as s14 se?
as the title says...are z32 rear rotors the same as s14 se? i cant seem to find any rotors, and i know of a parts z32 i can get em off of, jw if they will fit into the s14 calipers for the time being until i swap the z32 mc and f/r calipers
Team Rootbeer is offline   Reply With Quote
Old 02-28-2006, 08:31 PM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
They are both metal but thats it
You could have found this out on google or searching on here.
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 02-28-2006, 08:34 PM   #3
Irukandji
They're different. z32 rear ebrake is a drum brake, so the rotor design itself is different.
Old 02-28-2006, 08:37 PM   #4
Team Rootbeer
damnit, well that is all....thanks
Old 02-28-2006, 08:48 PM   #5
projectRDM
projectRDM's Avatar
They're exactly the same unless you consider the Z32 is one inch larger, wider, and vented.
Old 02-28-2006, 09:10 PM   #6
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
LOL, the post gets better everytime....
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 03-01-2006, 12:47 AM   #7
andrewmp6
andrewmp6 can only hope to improve
no they wont fit the s13 and s14 have soild rear rotors z32 are vented so there thicker and taller
andrewmp6 is offline   Reply With Quote
Old 03-01-2006, 12:29 PM   #8
Dopefish
Dopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really nice
Send a message via AIM to Dopefish
One thing that I cant get clear from the many threads I read are will the Z32 hubs bolt up to the S14 or do I need SE hubs in order to use the Z32 brake parts... I'm aware of the backing plate modifications needed for the Z32 e-brake but still not clear on the hubs themselves.
~Kris
It never got fast enough for me. -Hunter S. Thompson
Dopefish is offline   Reply With Quote
Old 03-01-2006, 12:33 PM   #9
SoSideways
SoSideways's Avatar
If you have 5 lug rear hubs then you can use Z32 rear rotors, as long as you have Z32 rear calipers to go with them rotors....
Old 03-01-2006, 12:35 PM   #10
Cashizslick
Cashizslick can only hope to improve
Haha good for a laugh.
IMHO z32 rears are not worth the effort to get & install.
Cashizslick is offline   Reply With Quote
Old 03-01-2006, 12:40 PM   #11
Dopefish
And e-brake cables (modified) and modified rear backing plates, and if I remember correctly something else...
The e-brake is a drum style instead of using the caliper, which is a benifit as it grips MUCH better than a standard caliper style e-brake but is a PITA to setup.
~Kris
Old 03-01-2006, 09:39 PM   #12
projectRDM
projectRDM's Avatar
No modification required for the backing plates, and none for the cables if you use R33s.
That's of course if you choose to use an ebrake. As far as the hub, S14 SE/Z32 work fine, or an S13 hub with a redrilled rotor to 4lug. Ebrake hardware still works fine on either model.
