Old 04-16-2012, 08:33 PM   #1
johnosu1
johnosu1 is an unknown quantity at this point
Send a message via AIM to johnosu1
collapse lifters
I have a collapsed lifters but I'm just going to replace them all. been lookin at stock lifters but haveing a hard time finding hyd lifters that aren't as much as tomie solid lifters. should I just go solid? also will Sr20de lifters work?? thanks
johnosu1 is offline   Reply With Quote
Old 04-17-2012, 01:53 AM   #2
riptor
riptor is an unknown quantity at this point
im here with you bro...i have one on the intake side of cylinder number 4.
riptor is offline   Reply With Quote
Old 04-17-2012, 09:11 AM   #3
johnosu1
how did u figure out for sure what cylinder it was. and what are u doing for lifters then?
Old 04-18-2012, 02:57 AM   #4
johnosu1
anybody know where I can get a set????
Old 04-18-2012, 03:57 AM   #5
riptor
heres what you do....my buddy showed me this one....its stupid simple and fuckin genious! take a wire coat hanger...cut the tip off of it and starightin it out,basically use pliers and make it into a stick. then using those same pliers take a screw driver, preferibly one a rounded end..not a flat one, and rap your new stick of wire around the handle of the screwdriver twice and do a twist tie style deal with the end...now you have a stethiscope(sp)...put the end of the screw driver into your ear..and make sure the tip of your wire "stick" is in contact with a flat surface, horizontal or vertical. you will beable to hear what is going on behind the scenes...thats how i found out what side it was.
