Old 02-05-2004, 01:12 AM   #1
TurDz
TurDz's Avatar
TurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the rough
Send a message via AIM to TurDz
sqeaking/creaking clutch pedal when released
Very often and lately, my clutch has been making some noise, and I'm positive it's coming from inside the car, where the spring mechanism is located. I've already oiled it with WD40 twice on different occasions, and used some bearing grease but the noise has come back.
the only thread I found was this one:
http://www.zilvia.net/f/showthread.p...t=sqeak+clutch
anyone have a more permanent solution to getting rid of the noise? I can't exactly pinpoint where the noise is coming from but it should be common among many 240 owners.
TurDz is offline   Reply With Quote
Old 02-05-2004, 01:28 AM   #2
thx247
thx247 is an unknown quantity at this point
the noise is probably from the clutch master cylinder inside the car. WD40 is not going to fix it, it will probably make it worse. Use some general purpose grease you find at your local auto parts store to lube the piston
thx247 is offline   Reply With Quote
Old 02-05-2004, 05:03 AM   #3
Sanchi
Macadamia Nut
Sanchi's Avatar
Sanchi is an unknown quantity at this point
Wow u too when its cold out side, every time i step on the clutch it squeeek's. Its so dam annoying. On hot days its not there. It comes and goes, been lazy to fix it. So no solutions as yet from me.
"Fear is the path to the Dark Side..., Fear leads to Anger, Anger leads to Hate, Hate leads to Suffering…" -Yoda
Sanchi is offline   Reply With Quote
Old 02-05-2004, 05:06 AM   #4
BlackS14
BlackS14 is an unknown quantity at this point
Send a message via Yahoo to BlackS14
I believe there is a small plastic bushing foung within (or around) the spring mechanism that, over time, deteriorates and breaks apart exposing metal to metal. This is where the squeaking you hear comes from. It happened in my car and after quite awhile, the noise finally went away. You could however buy a new bushing from Nissan and fix it that way...
-Bill
Once you go black you...well...you know.....lol!!!!
BlackS14 is offline   Reply With Quote
Old 02-05-2004, 06:21 AM   #5
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
I took my master cylinder apart a few months ago cause it had alot of black liquid in it, and when I put it back together it started squeeking too. Real damn annoying.
RedlineRacer is offline   Reply With Quote
Old 02-05-2004, 06:55 AM   #6
Bone
Bone is an unknown quantity at this point
Send a message via AIM to Bone
Same here on a 95 SE I think I am going to try white lithium grease.
Bone is offline   Reply With Quote
Old 02-05-2004, 01:56 PM   #7
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
Mine squeeks everytime it rains, cause when i step into my car and push in the clutch it squeeks. I get this because of my aftermarket pedals i put in and squeeks because the water from my shoes get between the aftermarket pedal and stock pedal.
SilviaSR20DET is offline   Reply With Quote
