Old 05-06-2012, 03:01 PM   #1
jacobzking
jacobzking is an unknown quantity at this point
Modifications for ISIS OIL PAN? FIXED! see solution
people have mentioned grinding down the oil pan, modifying the baffle... any photos or more details? I'm trying to get mine in right now and it won't sit flush.
jacobzking is offline   Reply With Quote
Old 05-06-2012, 03:28 PM   #2
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
Would of been better if you got the real deal, wouldn't it?
R@ddy is offline   Reply With Quote
Old 05-06-2012, 04:56 PM   #3
rc1honda
rc1honda's Avatar
rc1honda is an unknown quantity at this point
I would modify it to say Tomei, or GReddy.
rc1honda is offline   Reply With Quote
Old 05-06-2012, 05:29 PM   #4
Razi
Razi is an unknown quantity at this point
If it won't sit flat, get it machined flat by a machine shop.
Razi is offline   Reply With Quote
Old 05-06-2012, 05:36 PM   #5
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
Zilvia advice of the month award nominees right here.
omgRWDgoodness! is offline   Reply With Quote
Old 05-06-2012, 05:44 PM   #6
jacobzking
Would of been better if you got the real deal, wouldn't it? because i like cock in my mouth.
no, Greddy has same issue for many people, but thanks for absolutely nothing. I'm wondering if the people that don't have the problem... don't have the splash shield installed.
anyway, the key to the problem is modifying the splash shield (the flat plate that is exposed when you remove the oil pan). some people even just remove it, but if nissan thanks it should be there; i'll leave it there.
i cut off the rear lip of said splash shield. there are 2 problems. one is that the lip of the splash shield that points down, hits the edge of the oil pan since its a little thicker. the other problem is that i think the baffle waffle (circled below) also hit the splash shield. but by shaving of the lip of the splash shield with a dremel tool, everything lined up perfect.
THERE IS NO NEED TO MODIFY THE OIL PAN ITSELF... SIMPLY SHAVE OFF THE REAR LIP OF THE SPLASH SHIELD.
Old 05-06-2012, 05:49 PM   #7
stevecorrado88
stevecorrado88 is an unknown quantity at this point
Just use a grinder and take the part that's hitting off. I've owned 2 of them and both had the same problem. Never had a problem with the baffles tho.
stevecorrado88 is offline   Reply With Quote
Old 05-06-2012, 05:51 PM   #8
stevecorrado88
Grind off the part on the oil pan.
Old 05-06-2012, 05:52 PM   #9
jacobzking
yeah, i got in on. thanks though! I think i read your thread somewhere. i remember someone saying they had 2 with no problems.
Old 05-06-2012, 06:01 PM   #10
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Its common send just grind it down !!! End thread
S-Nation S13 is offline   Reply With Quote
Old 05-07-2012, 12:17 AM   #11
homeslicej2
homeslicej2's Avatar
homeslicej2 is making a name for him/her selfhomeslicej2 is making a name for him/her self
I have a Greddy pan. It fit perfect on my Redtop. I did not have to remove or grind down the shield (except to remove it temporarily to install a new S14 oil pickup and new gasket). Maybe the later model SR's have this issue?
homeslicej2 is offline   Reply With Quote
Old 05-07-2012, 12:42 AM   #12
R@ddy
Trader Rating: (32)
i also had the real GReddy oil pan with no issues. as a matter fact, i had it on 3 different SR's i've owned.
you could of also gone for the MOROSO which is a real nice one.
BUT since you already have the ISIS, might as well just grind down where it hits.
