Old 01-10-2002, 10:21 AM   #1
gregshin
gregshin is an unknown quantity at this point
I'm pretty close to ordering them....just wondering if any other springs are good...I'm just a daily driver.
gregshin is offline   Reply With Quote
Old 01-10-2002, 10:57 AM   #2
808rps13
808rps13 is an unknown quantity at this point
which springs are you thinking of getting?  the S21, DR21, or DR21 Supersports?  if you're just using them as a daily driver then you might find the DR21 Supersports too stiff.  IMO too stiff for a daily driver (IIRC 4.4kg/front, 3.8kg/rear), then you gonna need to find some well dampened struts/shocks to match up w/ them.
808rps13 is offline   Reply With Quote
Old 01-10-2002, 11:06 AM   #3
Drifting Ricer
Drifting Ricer is an unknown quantity at this point
I will put the s21 tomorrow! The rate is F4.6 R4.0.
Drifting Ricer is offline   Reply With Quote
Old 01-10-2002, 11:24 AM   #4
gregshin
ahh fook! there are 3 lines? i think i am getting the S21 i think...not to sure tho.
Old 01-10-2002, 11:48 AM   #5
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
either get the KG/MM dampers to go with them or the Tokico HTS's both of which are short stroke dampers designed for uprated springs that lower and stiffen your suspension. KYB AGX's are really good but they are stock travel height. which can induce bump steer if use with lowering springs
Old 01-10-2002, 12:00 PM   #6
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
To figure out what a KG/MM Rating is in LBS/IN just times the KG by 56.
So...
4.4kg/mm = 246 lbs/in
3.8kg/mm = 212 lbs/in
Now IMHO, that is WAAAY to soft. My old 5Zigen Springs were 290/280 and they were just right, but to each his own. I like stiff.
I will be ordering my Zeal B-6's in a custom Spring rate of 6.5 kg/mm Front and 5.5 kg/mm Rear. Which would be 364/308 lbs/in.
West is offline   Reply With Quote
Old 01-10-2002, 12:29 PM   #7
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from gregshin on 8:21 am on Jan. 10, 2002
</td></tr></table><span id='postcolor'>
Why not Eibach Pro-Kits? &nbsp;I think they have been universally praised, don't require special dampers, and firm the ride w/o harshness. &nbsp;
HippoSleek is offline   Reply With Quote
Old 01-10-2002, 12:36 PM   #8
vancouvers14
vancouvers14 is an unknown quantity at this point
Send a message via ICQ to vancouvers14
pro-kits are almost exactly the same spring rates as stock.
vancouvers14 is offline   Reply With Quote
Old 01-10-2002, 12:40 PM   #9
gregshin
so ya guys think i should get the Pro kits or KG/MM?A RGH!!! remember imma just a daily driver.
Old 01-10-2002, 02:01 PM   #10
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
I got H&amp;R springs for my s14 because I like the stiffness but not to harsh or to low for a daily drive in the north with the potholes and bumps in teh roads. &nbsp;I love my H&amp;R's. &nbsp;I got them from the &quot;House of imports&quot; guy on ebay. &nbsp;I think he is selling a set right now for like $190 or so. &nbsp;
burgy240 is offline   Reply With Quote
Old 01-10-2002, 02:07 PM   #11
tnord
tnord's Avatar
tnord is an unknown quantity at this point
i can't tell you the spring rates for stock springs and prokits, but i do know that my handling is drastically improved after the install, which is all that really matters
tnord is offline   Reply With Quote
Old 01-10-2002, 02:28 PM   #12
BlankFlip
BlankFlip's Avatar
BlankFlip is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from gregshin on 2:40 pm on Jan. 10, 2002
i've got intrax spring w/ a 2.0 inch drop cuz mine is a daily driver 2. they ride really really good for the drop, but i want something REALLY STIFF.
BlankFlip is offline   Reply With Quote
