Old 05-20-2012, 06:36 PM   #1
Keefs240sx
Keefs240sx is an unknown quantity at this point
Help quick with sr20 red top
Ok I just want to get more opinions on this problem. My car has a jumpy idle I've boost leaked tested an get 15 psi on the gauge an changed temp sensor as well. Motor only has aftermarket external gated an bigger turbo only on 8lb spring an stock injectors
Now when I run it down the road an come to a quick stop engine will idle down then jus die, it will start back up with no problems does it sound like an IACV ?
Keefs240sx is offline   Reply With Quote
Old 05-20-2012, 07:35 PM   #2
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
it should be close to -20 vacuum while sitting idle. you will still boost even though u have an a boost leak.
Old 05-20-2012, 07:40 PM   #3
sdrmiami
sdrmiami's Avatar
sdrmiami is an unknown quantity at this point
Send a message via MSN to sdrmiami
do you have a pic of your setup? where is your airflow meter located? if it is mounted to close to the turbo then when you let off under boost and the turbo back spools it will blow air back out the air flow meter causing it to stall out.. let me know
Team SDR! 305.992.1514
800hp SR20DET powered 240sx... Full street trim!
sdrmiami is offline   Reply With Quote
Old 05-20-2012, 08:06 PM   #4
Keefs240sx
Maf is about 1ft away from turbo inlet I don't have the filter on the maf waiting on adapter plate , as for Vaccum at idle it reads -20
Old 05-20-2012, 08:15 PM   #5
sdrmiami
sdrmiami's Avatar
strait pipeor does it have a bend in it?
Old 05-20-2012, 08:19 PM   #6
Keefs240sx
It's a 45deg elbow on it directed to driverside fender had to run it cause straight piece would hit cas
Old 05-20-2012, 10:34 PM   #7
wangan_cruiser
kouki man
Trader Rating: (36)
Check your vacuum routing
Old 05-21-2012, 10:38 AM   #8
AdamR
AdamR is an unknown quantity at this point
Explain "back spooling" please.
AdamR is offline   Reply With Quote
Old 05-21-2012, 08:49 PM   #9
Keefs240sx
Any one else have any solutions?
Old 05-21-2012, 09:07 PM   #10
nsfmike240
nsfmike240 is an unknown quantity at this point
check the level of coolant , if its low the idle will jump up and down
nsfmike240 is offline   Reply With Quote
Old 05-22-2012, 12:27 PM   #11
Keefs240sx
I have its full to top of radiator anything else?
Old 05-22-2012, 02:09 PM   #12
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
My car has a crappy idle too and as no one has really thrown you solutions to check that seem to make a difference. Get some maf cleaner, there is specific spray for mafs. Take out maf, and gently feed the red straw thru the screen and carefully spray off the filliment. Keep the straw an inch or so away from the sensor, also make sure your maf is wired in right too. I still need to check this on mine. But I guess it'll still run with a couple wires switched but rich and shitty. Your vacuum lines as well. are they routed right and not cracked or rotted out. I'm about to order a wiring specialties harness just to rule out a 20 year old rotted, heat soaked wiring nest.
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
Old 05-22-2012, 04:28 PM   #13
Keefs240sx
I have the harness too
Old 05-22-2012, 04:47 PM   #14
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
u need to check voltage to iacv
even if its a premade harness....if the car has voltage fluctuations on any thing to ecu or sensors car will run crappy
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 05-22-2012, 06:25 PM   #15
Keefs240sx
What's is the specs/voltage should I have at the iacv?
Old 05-24-2012, 06:14 PM   #16
Keefs240sx
Still no luck . Help needed
Old 05-24-2012, 06:22 PM   #17
SofaKingFast
Trader Rating: (43)
SofaKingFast is an unknown quantity at this point
Feedback Score: 43 reviews
Send a message via AIM to SofaKingFast
Sounds like you're not re-circulating your BOV?
SofaKingFast is offline   Reply With Quote
Old 05-24-2012, 06:31 PM   #18
240zach
240zach's Avatar
240zach is an unknown quantity at this point
have you tried to run full compressor surge or recirculated bov and see if that stops the low idle? have you ever thought that maybe your bov is leaking?
240zach is offline   Reply With Quote
Old 05-25-2012, 06:31 AM   #19
JapaneseAutox
JapaneseAutox's Avatar
JapaneseAutox is making a name for him/her selfJapaneseAutox is making a name for him/her self
What the hell is up with everyone's grammar in this thread? Use god damn punctuation marks.
What other information can you relay upon us about your setup? Are you still running the stock ecu or is it a stand alone with someone else's tune? Did you build the engine or did you buy it from someone else? It may have aftermarket cams in it throwing off the idle and tune (this happened to me before). I wouldn't recommend driving anywhere without the filter unless you want to kill your engine. Be patient and wait for your adapter. Your problems sound like a boost leak to me. Go to your local hardware store and fabricate a boost leak tester. Pressurize the system then spray soapy water on all of your couplers and look for bubbles. Couplers can often hold vac but leak boost when the pressure exceeds a certain amount. Check your bov spring. Make sure your maf plug isn't loose. Kill that damn SR gremlin. Good luck.
JapaneseAutox is offline   Reply With Quote
Old 05-25-2012, 07:49 AM   #20
projectblak
projectblak is an unknown quantity at this point
what kind of BOV are you running, is it recirculated?
projectblak is offline   Reply With Quote
