![]() Join Date: Mar 2011
How do i reset a s14 "fuel float"??
Hey first off sorry if this is "millionth" post of how to reset a s14 fuel float or whatever ya call it.... but anyways the main prob is that my stock fuel gauge reads a little inaccurate and researched that resetting the float would fix this common issue... sooooooo if anybody can point me in the right direction in how to do so would be some weight off my shoulders THANKS in advance
#5 | |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
My fuel gauge stays low even after I fill up for the first 30 miles.
Then it goes up and down all over the place throughout the life of the tank. I gave up on it and use the tripometer exclusively now.
![]() Best way to do business with me? Make your best offer FIRST. |
#7 | |
#8 | |
![]() Join Date: Jun 2009
Yeah the float slides back on and "locks" in place but the design sucks doesnt lock as it should cause when i put mine on i wiggled it a bit and popped off again so you can imagine sliding in your car and having gas sloshing around would prob make the float come loose again so i used the steel wire and wrapped it around the opening of that clip/bracket and float and used it as a wire tie, looping the wire around the float was a pain lol and i just twisted the 2 ends to make a tight and sung fix almost gave up on doing that idea lol just take your time if you decide to it.
![]() Hey, man I got the same problem with my Zenki, my fuel gas gauge no longer works, it's hard for me to tell how much gas do i have, I checked the fuse, still fine, could it be the float itself? anyway could you at least post a picture on where to locate the float inside the fuel tank, because i have no idea how does the float looks like..
#11 | |
That could be either a failing sending unit, or it might be that your float is partially filled with fuel. That would screw with the buoyancy, causing the float to surface slowly and submerge at random times. |
#16 |
#18 |
Did you happen to have the same problem as mine, like my gas gauge wont work? And I haven't try taking out my floater yet, are you able to show me how to take it out from my s14? and do you think this will solve the problem?
#19 |
![]() Join Date: Apr 2008
![]() Feedback Score: 9 reviews
I took my floater out, which is easy to do, its like removing the fuel pump, yes, the gauge was off for example, it said I had half a tank when I was almost empty, or vice Versa, when I take it out and move the ball around it resets to what I actually have, it doesn't come out of the bracket like all the others, but then a few days later, the gauge is inaccurate again
#20 | |
