Old 06-14-2012, 12:05 PM   #1
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
Brand New set of Drift Freaq KA/SR/CA Engine mounts
yup here they are 80 durometer track tested high quality poly urethane engine mounts. There is a link in my sig that will take you to a multipage reveiw. Lots of people here are using my mounts.
The studs do not run straight through the center of these mounts unlike other brands.
You will not get any excessive vibrations from these because of this.
You will get mounts that are better than Nismo and do not rattle your teeth.
The studs are also offset so you can adjust your engine positioning up or down 1/2-3/4 of inch.
You need to use a heat shield or a heat wrap on the exhaust/turbo side of the engine.
I also should point out that the nuts that are provided are nyloc which means you do not need to torque them down hard. A hand wrench is fine for tightening them. Do not use an air ratchet or impact gun.
Here is a Brand New set of the Greens which are the latest design. $120 picked up $136 shipped my paypal is [email protected]
New Video
Buy my mounts!
