Old 02-16-2012, 04:46 PM   #1
rynftw
rynftw is an unknown quantity at this point
KA s14 egr vacuum line help!
okay so i deleted my egr, but i wasn't exactly sure what to do with the vac lines and what goes where...but my car WILL NOT IDLE! need help! AHHHHH!
rynftw is offline   Reply With Quote
Old 02-16-2012, 10:14 PM   #2
Infamax
Infamax's Avatar
Infamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enough
Pull off the vac line and plug up the nipple.
Infamax is offline   Reply With Quote
Old 02-17-2012, 10:19 AM   #3
rynftw
which one? do i pull the metal bracket thing off that has the mass of vac lines? so lost...grrr
Old 02-17-2012, 01:04 PM   #4
Infamax
Infamax's Avatar
What else did you remove when you removed the egr valve? Did you remove the bpt valve and the exhaust tube?
I found this link, maybe it will help you.
http://tech.240sxone.com/115/ka24de-egr-removal/
Old 02-18-2012, 10:28 AM   #5
rynftw
basically, there is no more emissions equipment to speak of. carbon canister is gone and egr is gone and i'm just left with a nest of vac lines. :\ considering putting the egr back in if it'll make my car run better
Old 02-18-2012, 11:52 AM   #6
Infamax
Infamax's Avatar
Follow step 5 in the link I provided.
Old 06-29-2012, 12:46 AM   #7
truetrueno86
truetrueno86 is an unknown quantity at this point
I am having the same problem also. Do not know how to hook up the vacuum lines after an egr delete. I can find stuff on the s13 but not anything on the s14. let me know if you have figured it out yet. a picture would be great.
truetrueno86 is offline   Reply With Quote
Old 06-29-2012, 01:04 AM   #8
BoostWanted
BoostWanted is an unknown quantity at this point
Try plugging the end of the vacuum line that goes to the egr or charcoal canister, or whichever line, with a screw.
BoostWanted is offline   Reply With Quote
Old 06-29-2012, 10:43 AM   #9
ka4life87
ka4life87 is an unknown quantity at this point
Ka's have a ton of vaccum lines and are all for emissions only, bpt, asv, charcoal canister, egr, ect. There is metal vacuum distribution lines bolted to lower intake, remove lower intake and plug all vaccum sources, only need one which goes to fuel pressure regulator and thats tapped to side of intake.
ka4life87 is offline   Reply With Quote
