Old 06-18-2012, 06:48 PM   #1
Arireese
Arireese is an unknown quantity at this point
Sr20det Runs like shit help
My buddys sr is running like shit. just put the motor in awaiting on a turbo to manifold gasket. Not sure if that is the cause of this problem but it leaks pretty bad.
Tried Maf so far. from my car(good maf). No boost or vaccum leaks
wiring for maf is good too.
car idles at 400-500.
sometimes if you unplug the maf it bumps up to 900, but if you rev it it just dies.
Car revs perfect except for a studder at 3k, when the car is underload it bucks really bad.
its a type x motor running non type x harness and ecu btw.
Arireese is offline   Reply With Quote
Old 06-18-2012, 09:48 PM   #2
towlie
If its a true type x motor with a earlier ecu that might be the problem. The ecu's are different
Old 06-18-2012, 11:18 PM   #3
Arireese
It is cause they gave us the ecu that was with the motor..but harness off another random one
Old 06-21-2012, 06:00 PM   #4
Arireese
helpppppppppppppp
Old 06-21-2012, 06:26 PM   #5
anarchyperf
anarchyperf's Avatar
anarchyperf is an unknown quantity at this point
A bad exhaust leak will def create a problem with a Maf based setup. Check the ecu to see if you have any codes. If you don't have any codes then it's probably not a harness problem.
www.anarchyperformance.com - Your source for 240sx Performance!
https://www.facebook.com/anarchyperformance - Like us on facebook
Email: [email protected]
anarchyperf is offline   Reply With Quote
Old 06-21-2012, 06:34 PM   #6
Arireese
throwing maf code 12, ran the car with my maf, and it ran a little better. but still broke up. still waiting on the gasket to come in so we can change that. the turbo is falling off the manifold pretty badly. so im hoping that maybe with a good maf, and the gasket fixed it fixes it. cause its my friends car and i did his swap and now i feel bad lol
Old 06-21-2012, 07:12 PM   #7
anarchyperf
The engine temp sensor and O2 sensors are different as well but def get that leak taken care of.
Old 06-21-2012, 07:16 PM   #8
Arireese
okay ill swap them out with redtop ones..is that fine?
Old 06-21-2012, 07:23 PM   #9
anarchyperf
Should be...I'm not sure how many wires the Type-X O2 sensor is though so you may need to do some rewiring
Edit: Ignore the comment about rewiring. Obviously if your running the redtop harness and ecu the redtop O2 is just plug and play
Old 06-21-2012, 07:27 PM   #10
Arireese
already running a normal fat 02 from a redtop. just never swapped the temp sensor.
Old 06-21-2012, 07:46 PM   #11
steve shadows
steve shadows's Avatar
I love the title of this post. LOL Simply because it's just so honest.
Where are you located? If you can somehow limp it over to my house in Long Beach, CA area I can probably check and fix it for a small fee. Otherwise I would definitely look into IACV issues, ECU wiring shorts and wiring gremlins.
Like Me on FaceBook !
Old 06-21-2012, 07:47 PM   #12
steve shadows
Nevermind you're in Philly.
Ok It sounds to me like you have the wrong MAF, or you have timing that is EXTREMELY off...i.e. the CAS or Crank Angle sensor is way way out of position.
The other option is fuel. You fuel pump could be dying.
Does the car see to be running too rich or too lean? And is there anything coming out the back of the tail pipe that could cue you into more failures?
Thanks
Old 06-21-2012, 07:52 PM   #13
Arireese
Thanks
tried dohc, redtop, and sohc. runs best with my sohc maf on his car. tons of black smoke that burns your eyes.
Old 06-21-2012, 07:56 PM   #14
steve shadows
I can pretty much guarantee there is a fub-up in the wiring. Make sure the wiring is 100% correct. Each maf has a different pin out and if one wire is off you could end up sending full 5 volts down the signal input to the ecm, possibly damaging that part of the ECU and also making the car run full rich at all times.
Old 06-21-2012, 07:59 PM   #15
Arireese
maf wiring was checked multiple times it looks exactly like mine, also runs the same maf number, so they have the same pinout. ecu looks to be socketed, but has no chip.
Old 06-22-2012, 02:16 PM   #16
zneubauer
zneubauer's Avatar
zneubauer is an unknown quantity at this point
save yourself the worry and get the correct harness and ecu, it will give you piece of mind and might even eliminate the problem.
zneubauer is offline   Reply With Quote
Old 06-22-2012, 03:42 PM   #17
cotbu
cotbu's Avatar
eliminate the ecu, either swap his to yours or vice versa, as long as he has no wiring issues, your ecu should be safe, maybe!
Old 06-22-2012, 04:40 PM   #18
Arireese
haha well the ecu matches the harness. but im still scared to try my ecu out on his. what if i tried his ecu on mine? same deal right?
Old 06-22-2012, 05:06 PM   #19
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
nothing will happen tothe ecu. you car will just run like crap if the other ecu is bad. Then you will know its a bad ECU and not wiring or anything else.
Check Out My S13 Build
EvoVIII808 is offline   Reply With Quote
Old 06-22-2012, 05:12 PM   #20
Arireese
oh no i was saying im scared to try my ecu in his lol.
gonna give that a try after im done painting my car.
Old 06-22-2012, 05:20 PM   #21
EvoVIII808
ohh ok, yeah give it a shot. should help you figure out the problem.
Old 06-22-2012, 05:27 PM   #22
Kenzo
Kenzo is an unknown quantity at this point
Need help looking it over? I'm pretty sure we've talked before on here. I was able to un-fuck my CA18 I may be able to un-fuck his engine.
Kenzo is offline   Reply With Quote
Old 06-22-2012, 05:28 PM   #23
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
some type x motors use different ecus (j4) and harness
the pin out on those harnesses are different from the redtop harnesses
a reptop ecu will not work w a type x harness
i got a complete type x ecu (j4) and harness for sale =)
c-los13 is offline   Reply With Quote
Old 06-22-2012, 05:32 PM   #24
Arireese
oh shit you bought that older black dudes ca hatch! haha. i miss my ca..whats your name you live in philly and have a 240 but i dont know you..weird!
Old 06-22-2012, 05:33 PM   #25
Arireese
already went through this..at the importer place we bought the motor that had no harness on it, they gave us the ecu to go with it. didnt look that it was a j4. picked up a harness, wired it up. then car would barely run, realized oh shit itsa j4 ecu and the pinout doesnt match up with anything, so got a ecu that matches the harness and it started right up.
Old 06-28-2012, 03:50 PM   #26
anarchyperf
Any progress?
Old 06-28-2012, 09:45 PM   #27
Arireese
yeap fixed it..im an asshole..
extended the black and white maf wire with a black wire. So automaticly for some reason i soldered it to the black wire..switched them around and boom. car is good. Lol
Idiot, I did all the wiring but the maf wiring at my house(so i could see how long it needed to be), then waited last minute at the end of the day to do that and i was tired and it was like 105 degrees out haha, oh well fixed now all he needs is a non hicas ps pump
Old 06-29-2012, 02:39 PM   #28
anarchyperf
I have a ps pump
