Old 06-24-2012, 09:47 AM   #1
ze12o
ze12o's Avatar
Trader Rating: (26)
ze12o is an unknown quantity at this point
Feedback Score: 26 reviews
Turbo getting too hot?
Recently sent my turbo to Turbos Direct in TX. They had their techs open the turbo up to inspect it. The guy calls me and tells me the turbos getting too hot and he said to get it better cooled or it wont last another 1500 miles.
I daily the car but not far and rarely push the car but when I do I really push it.
Here's my routine:
Start up
Warm it up til operating temp (via oe water temp gauge)
Wait til oil press drops to <60psi
Shut down
Drive out of boost for a few mins
Turbo time for minimal 1-2mins Hard drives 2-4mins
Setup:
93 s13 ka
Garrett T3 GT35R Top mounted
Water cooled (lines running from throttle body)
Oil:
Skulls and bones Oil block -->
-3an ssline -->
Earls -4an inline oil filter -->
Turbo -->
-10an drain
Ebay -8an oil cooler (not sure the size)
Trust GREX oil filter relocation block w/ thermostat
-8 oil lines
Koyo radiator
Stock clutch fan w/ shroud
Down pipe wrapped
Turbo blanket
Soon to install a nismo thermostat - water and oil temp gauges.
Any tips or recommendations would be greatly appreciated
-K
ಠ_ಠ
ze12o is offline   Reply With Quote
Old 06-24-2012, 08:41 PM   #2
jedi03
wat temp is it...also maybe check ur afr
Old 06-24-2012, 09:07 PM   #3
Sileighty_85
Sileighty_85's Avatar
EGT's Might be to high.
Engine is running lean possibly
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-25-2012, 12:39 AM   #4
Rut Ro
Rut Ro's Avatar
Rut Ro is an unknown quantity at this point
Yup. Check your air/fuel ratios. Probably running lean like Sil said.
Rut Ro is offline   Reply With Quote
Old 06-25-2012, 08:15 AM   #5
Croustibat
Imho not a problem of water / oil cooling, but more something to do with poor / no mapping, too small injectors and too small AFM. I hope you are not running a boosted engine with stock fuel system, air metering and oem tune, otherwise you sure are making holes in your pistons ...
As always, do things right. Slapping a turbo on an NA engine and hoping it will work is not the right way.
Old 06-25-2012, 02:13 PM   #6
!Zar!
!Zar!'s Avatar
You want to keep the turbo hot, that's why you insulate the turbo. I believe they run best at 1500 degrees f.
Also, warming your car up is no good.
Wait maybe 5 seconds or so to build oil pressure, then keep revs low till it warms up.
Old 06-25-2012, 03:20 PM   #7
ze12o
ze12o's Avatar
Trader Rating: (26)
Don't have a water or oil temp gauge yet. but i will soon
AFR is 14-15 @ cruising 11-12 @ WOT idles @ 14.7-15
Car would have blew the motor already. I'm running
750cc injectors
greddy fuel rail
walbro 255
tomei fpr
tune is from efi specialist for my setup.
I also have a knock light which has only come on once with mild knock at 3rd gear @ 6.5k
I know this already. Hot air moves faster. But guys at turbos direct is saying it is getting too hot. That the insides are cooking.
And my car cold starts with over 130 psi. Is that really safe to drive on?
ಠ_ಠ
Old 06-25-2012, 03:42 PM   #8
Croustibat
if you can get an EGT sensor, try to install it ... but i cant see what you can do to cool it down, unless you use lower boost and a less aggressive ignition map :/
Old 06-25-2012, 04:01 PM   #9
Rut Ro
Rut Ro's Avatar
Take off the turbo blanket then?
Old 06-25-2012, 04:18 PM   #10
ze12o
ze12o's Avatar
Trader Rating: (26)
I'm running 9.6lb spring. and I'm thinking about removing the blanket but it is really close to the bmc.
ಠ_ಠ
Old 06-26-2012, 12:12 AM   #11
Rut Ro
Rut Ro's Avatar
I can't remember who makes the shields for the bmc. But they work pretty darn well. Only reason I can think of on why the turbo is getting too hot is because of the internals are cheap. That's not like Garret either.
Old 06-26-2012, 12:13 AM   #12
Rut Ro
Rut Ro's Avatar
Megan Racing. You can get one on frsport.com.
Old 06-26-2012, 02:01 PM   #13
!Zar!
!Zar!'s Avatar
What exactly is, 'getting too hot'?
What has accelerated wear to the turbo which makes the shop believe it is due to overheating?
I highly doubt your turbo is getting hot enough to glow like this.
As said before, running too lean will cause danger to t3h manifold.
Old 06-26-2012, 02:14 PM   #14
kikcaffine
kikcaffine is an unknown quantity at this point
sounds like the shop is full of shit and looking for an out if they actually repaired anything......
kikcaffine is offline   Reply With Quote
Old 06-28-2012, 10:37 AM   #15
ze12o
ze12o's Avatar
Trader Rating: (26)
I use a circuit sport heat sheild it's pretty nice but still gets hot.
I found it weird too. they said the turbos all black and blue inside. which points to over heating. I thought turbos were suppose to see high heats like that.
Sometimes I think so too. They are a big shop though and authorized by garrett.
I'm going to hook up a safc to fine tune the efi specialist tune.
ಠ_ಠ
Old 06-28-2012, 11:33 AM   #16
kikcaffine
What size exhaust? Do you have a cat?
Old 07-02-2012, 02:51 PM   #17
J90lude
J90lude's Avatar
J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude
It really kills me when mechanics at shops don't know their shit or either their trying to get over you. Similar to what kik said....
"Drive it like you running from the cops"
J90lude is offline   Reply With Quote
