A/C Help. Expansion Valve blocked? Drier Clogged?
My air conditioning is confusing me. I have searched all morning for answers.
CAR: 1997 240sx SE. All OEM. 198,000 miles. Basically I took my car to get a recharge this morning (AC only gets cold at highway speeds). The mechanic showed me: LOW PRESSURE SIDE is way too high (70ish) HIGH PRESSURE SIDE was basically normal Now, we both knew there was a clog in the system, but I old him to go ahead and purge/recharge to see if it would clear up the problem. After the vacuum/recharge, we saw: LOW PRESSURE SIDE is wayyyy too high (75 after just 1 can of R134a) HIGH PRESSURE SIDE was basically normal And now after this, I have no cool air, and my expansion valve is "hissing" when I turn the AC on. I know that sometimes they hiss when there is low refridgerant, which would make sense in this case, as we only added 1 can. My compressor is fine. All electronics/sensors SEEM to be working fine. My questions: 1. Do 240sx's clog Expansion Valves frequently? I plan to replace this. 2. Should I replace my Drier/Liquid tank with an OEM unit, or generic (Advance auto) unit? Is this necessary? 3. Is blowing compressed air through the system a bad idea? (due to moisture contamination). I would assume so, and I don't plan to, but I am just curious. 4. Has anyone encountered a similar problem. Anyone with experience please chime in. Thanks.
Jets > Cars |
