Old 07-20-2012, 08:35 AM   #1
maxgohan
maxgohan will become famous soon enoughmaxgohan will become famous soon enoughmaxgohan will become famous soon enoughmaxgohan will become famous soon enough
replacing clutch, machine flywheel? what other parts needed?
I need a rear main seal replaced and my clutch is worn out so I'm replacing that
what other parts should I replace that would be prudent while the tranny is off?
Also, do I need to machine the flywheel? talked to a shop and they said the service manual doesn't tell you to machine the flywheel
maxgohan is offline   Reply With Quote
Old 07-20-2012, 10:48 AM   #2
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
machine flywheel dont listen to nobody...
and i usually do both master and slave for clutch too
and switch to a high temp fluid for clutch hydraulic
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 07-20-2012, 12:48 PM   #3
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
machine the flywheel, new throwout bearing, friction disc, pressure plate, rear main seal (
OEM preferred) possible new diff fluid since it might spill out.
you need to go to a clutch shop near you, i got mine done for 15 bucks. But the reason for machining the flywheel is to ensure the new pressure plate and clutch is attached to a new surface, basically its like doing brake rotors, you dont have to but this is your clutch its harder to get to just incase it messes up lol
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 07-23-2012, 07:47 PM   #4
green_pea
green_pea's Avatar
green_pea is an unknown quantity at this point
things you should be changing/aquiring for change
-flywheel bolts
-torque wrench fo flywheel bolts
-gearbox oil GL4
-threadlock for flywheel bolts
-clutch aligning tool
-flywheel machining
-new throwout bearing
-spigot bush/bearing?
nationaldriftographic.blogspot.com/
green_pea is offline   Reply With Quote
Old 07-23-2012, 08:09 PM   #5
Wookie384
Wookie384's Avatar
Wookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really nice
Send a message via AIM to Wookie384
I always replace:
- Clutch disc & pressure plate
- Throw out bearing
- Pilot bushing/bearing
- Flywheel blots (and the ones for the pressure plate)
- Rear main seal
I always replace those and I always resurface the flywheel, I also inspect the fork for the throw out bearing and the pivot ball/bolt and replace as necessary.
Wookie384 is offline   Reply With Quote
