Old 02-11-2004, 07:52 PM   #1
Doriftomodachi
Doriftomodachi is an unknown quantity at this point
s14sr20det with HKS Hi Power 60mm piping, for now...
What’s up everyone. I just test drove my s14 with the s14sr in it. A few things to note: It still has my HKS Hi Power ka exhaust with 60mm piping. It has the stock side-mount i/c, an HKS DD filter and a Tomei 255lph fuel pump. Klay at Motorex also set the timing back to “break in” the engine. With that in mind, it felt like a strong engine and it was very smooth all the way to 7000rpm. It also felt “restricted” and a bit sluggish, though. I will be getting a gp sports spec R stainless exhaust with 80mm piping this week. Do you think adjusting the timing and replacing the exhaust will make a big difference? Thanks!
Doriftomodachi is offline   Reply With Quote
Old 02-11-2004, 08:08 PM   #2
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
80mm exhaust on our cars are dyno-proven, 20+ at the wheels. Ask Nadine.
It's a turbocharged car, so yes, bigger exhaust pipes will make a drastic improvement.
I would also recommend babying the engine for about 500-1000 miles... you may want to change the oil after the first 100, you'll see that its black as all hell (all the builup and crap from the motor sitting).
Run some Mobil-1 and also use some Marvel's Mystery Oil on it.
Stuff works miracles!
Have fun with your new motor and let us know what happens when you get the new pipes!
kazuo is offline   Reply With Quote
Old 02-11-2004, 10:25 PM   #3
Doriftomodachi
20+ huh? Cool! thanks for the heads up I will change the oil after 100 miles too.
Old 02-12-2004, 10:23 AM   #4
mellojoe
mellojoe is an unknown quantity at this point
the first oil you sould use in an engine thats been siting is NOT Mobile 1. Use conventional oil. It is a bit thicker and has a tendancy to "coat" the internals. Mobile1 is just TOO slippery to break the engine in. After about 500 miles or so, I'd go with Mobile1. Change the oil after 100 miles. Then change again at 500 miles. That's another reason to go with cheap-o conventional oil: its less expensive since you will be just throwing it out after very few miles.
mellojoe is offline   Reply With Quote
Old 02-12-2004, 02:56 PM   #5
DudeYourSoOOJDM
DudeYourSoOOJDM's Avatar
DudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud of
Send a message via AIM to DudeYourSoOOJDM
I heard the piping on those exhausts is very thin, the mufflers come apart from the insides and overall quality isn't very good.
This is from someone that owns one.
Since 2001.
DudeYourSoOOJDM is offline   Reply With Quote
Old 02-12-2004, 07:02 PM   #6
Doriftomodachi
sadly i heard the same but i will run it until i can get an 85mm hks hi power
Old 02-21-2004, 12:37 AM   #7
Doriftomodachi
Well, I ended up getting an apex n1 single brand new in the box for $300!! Much props to richardxfeng for hooking this up! Man WHAT A DIFFERENCE!!! The car pulls insanely now! Today I was following a lan evo making a right turn and he tried to pull away from me. We ran for about 1/8th of a mile and my car stayed with him (!) then I turned into the dealership so it ended there. He started pulling away just so slightly but he must have been trippin on a 240 keeping up with him. Very happy with my sr swap. Much props to Klay and Motorex
Old 02-21-2004, 01:17 AM   #8
Fibercus
Fibercus is on a distinguished road
Send a message via AIM to Fibercus
Is it just me or does that VVT / VTC make for a sweet powerband? I cant stop posting about it
Congrats on everything,
Oh btw, Do you also have a bit of traction issues with your will and open diff (if you do have an open diff)?
Fibercus is offline   Reply With Quote
Old 02-21-2004, 03:57 AM   #9
Heartwork
Heartwork's Avatar
Heartwork is an unknown quantity at this point
do u still have yoru HKS N/A exhaust?
if you still do, i'll buy it off of you, or would u like to trade for my brand new/unused Schroth Autocontrol harness?
Heartwork is offline   Reply With Quote
Old 02-21-2004, 05:02 AM   #10
strykrsilvia
strykrsilvia is an unknown quantity at this point
I had the 60mm hks dragger on my sr first and it was sluggish. then I went with hks hi power and I loved it. It knocked a 1/2 second off my 1/4 mile runs by its self.
strykrsilvia is offline   Reply With Quote
Old 02-22-2004, 02:33 AM   #11
Touring240
Touring240 is on a distinguished road
unless your breaking in a new clutch... you don't need to break in a used motor.
changing the oil in the first week is a good call however
Touring240 is offline   Reply With Quote
