Old 07-18-2012, 12:19 PM   #1
el ocho
el ocho is an unknown quantity at this point
powerfc problem
My d-jetro is reading -34 degrees airtemp whether the sensor is plugged in or not. Tried replacing the sensor and still the same result. Wired it according to this Apexi Power FC SR20DET D-Jetro IAT Intake Air Temp Sensor Pinout and Wiring . Any info is appreciated.
el ocho is offline   Reply With Quote
Old 07-18-2012, 12:41 PM   #2
inopsey
the info for the brown wire is wrong. it goes to a specific wire on the oem harness. find the correct info on the apexi website.
http://www.apexi.co.jp/pdf/pfc_pdf/7507-0380-02.pdf
Old 07-23-2012, 02:09 PM   #3
steve shadows
steve shadows's Avatar
Exactly. Make sure you wire up the harness porperly on the D-Jetro I always see people with problems with the D Jetro and it's always - at least 95% of the time an issue with how they wired up the MAP/plugged in etc and the Air Temp.
Like Me on FaceBook !
