02-24-2004, 03:01 PM | #1 |
$1.00 Tune Up
Everyone repeat after me:
"I will remove my MAF sensor and clean it!" I did this yesterday, took 10 mins, used some rubbing alcomahol and a qtip to clean out the inside of it which apparently conducts electricity through the whole inner surface of the tube as well as cleaned the little dangly wire thinghy..Car Idles better, feels a bit smoother and peppier and seems to be using less gas although ill withold judgement on that till I drive some more
Who the hell needs a sig anyhow |
02-24-2004, 03:21 PM | #2 |
Is there a reason why you used rubing alcohol to do this? Is there a beter way to fi this like just blasting it with a spray? Does intake/throttle spray work? Does car cleaner work?? Just wondering cause I would like to clean mine as well.
02-24-2004, 03:45 PM | #3 |
i have a can of throttle body cleaner for instance
it says "leaves a lubricating film behind" so I didnt use that...You could probably use brake cleaner but I had the rubbing alcohol and qtip already
02-24-2004, 06:07 PM | #6 | |
Alcohol won't mess it up or anything ,would it? |
02-24-2004, 07:10 PM | #7 |
shiet..I should do that too...! but it looks clean..maybe it's the electric part..hopefully it saves me gas..cuz..it's hella expensive now!
-Cherry Red 91 Silfourty- |
02-24-2004, 08:23 PM | #12 |
I've been meaning to clean mine for a while. Just did it... rubbing alcohol and a Q-tip. The only part you need to clean is the tiny thermistor. I didn't feel a difference....
02-24-2004, 08:33 PM | #13 | |
Isnt there current going through the whole thing? I definitely felt a difference...maybe yours wasnt dirty |
02-24-2004, 08:45 PM | #14 | |
02-24-2004, 11:20 PM | #17 |
GhettoKracker, it's not there yet? Dam postal people. Let me know when you get it. I'm going to go clean mine now. My car seems to be using more gas lately.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing. |
02-25-2004, 10:41 AM | #19 | |
nightwalker:not yet....I haven't gotten the mail for today though....I'll let you know when I do get it |
