Old 08-02-2012, 08:06 PM   #1
nissan1310
nissan1310 is an unknown quantity at this point
All out race engine SR20DET with z33 trans and TOMEI ARMS TURBO
This is what i got s13 sr20det comes with alot of good parts
Eagle Rods $350
Arias piston 8.5.1 87mm $590
BC Cams 264 $320
BC valve spring and retainer $220
ARP head bolt $160
NISMO head gasket $220
Tomei solid pivot lifter $230
Tomei rocker arm stoppers $110
All new OEM shims $100
OEM valve stem seals $80
ACL Race main and rod bearing $140
All new OEM seal and gasket also timing chain, guide, tensioner $300
OEM water pump $70
OEM front cover oil pump $240
Fidanza cam gears $120
ARC lower oil pan $330
JDM engine mount (used) $150
Tomei Arms M7960 Turbo kit $1240
ORC single plate clutch $700
Transmission adapter plate to z33 trans $450
Z33 350z transmission with shifter relocate and bell housing milled with 37k mile $750
ISIS down pipe $90
ISIS intake manifold $180
ISIS 3" turbine outlet $100
ISIS exhaust manifold $200
ISIS radiator hoses $40
300zx MAFS $100
All machine work , engine assembly done by Chastain engine center in atlanta GA $800
The total amount i spent around $8380.00 0 MILE ON THE ENGINE
Im asking $7850 OBO if you have any question you can call or text
me at 404 729 9488
nissan1310 is offline   Reply With Quote
