Old 09-03-2012, 09:28 PM   #1
Flushed_S14
Flushed_S14's Avatar
Flushed_S14 is an unknown quantity at this point
Power Steering Problem.. Any advice?
My power steering system in my S14 is getting me frustrated. Recently I replaced some power steering lines that were damaged and now my steering wheel goes all crazy after a few seconds. (Front wheels are off the ground)
I am aware that you need to bleed the power system by turning the wheel left and right but it goes all crazy and doesn't allow me to do it. I know its not a bad power steering pump because i've tried 3 and I get the same results with all of them.
My QUESTION is...Is there any other way to bleed the system? Can someone elaborate please.
Note: I was driving my car without power steering for about a year. Idk if that matters in choosing what method to use. Help would be appreciated. Thanks
Flushed_S14 is offline   Reply With Quote
Old 09-04-2012, 06:47 AM   #2
mightymike130
mightymike130's Avatar
mightymike130 is on a distinguished road
Did you check if your power steering rack bushings aren't shot to hell? If they are its a quick cheap fix
mightymike130 is offline   Reply With Quote
Old 09-04-2012, 09:40 AM   #3
Flushed_S14
No I haven't...I didn't know that would matter. What else could it be if its not the power steering rack bushings?
Old 09-04-2012, 01:10 PM   #4
cotbu
cotbu's Avatar
I remember a member here with a power steering problem, don't know if it's the same thing but that shyt was crazy! He had the lines backwards I believe.
http://zilvia.net/f/tech-talk/127032...-posessed.html
It was kinda like this, but more hilarious!
http://www.youtube.com/watch?v=MLHWgAmx3Iw
Old 09-06-2012, 10:56 AM   #5
Flushed_S14
I don't think I have them backwards but just in case...Does someone have a diagram of some sort that shows how they go?
Old 09-06-2012, 10:59 AM   #6
dt-p88
dt-p88 is an unknown quantity at this point
Yeah I bet they are backwards, it happened to me on an s13 before. the lines that bolt to rack were backwards.
dt-p88 is offline   Reply With Quote
