Real RHD S14 Silvia Zenki North GA
This car is registered and I will disclose the information to interested buyers in person. I will not argue what is legal and what is not. I've been pulled over for antagonizing the fuzz and never received a ticket. Tagging this car was not a problem. I can not speak for states or city's outside GA.
I've owned this car for about 2.5 years. I bought the BARE shell and put the whole car together myself. It was fun and expensive finding parts in a dozen different country's that this was missing. Everything is perfect and I can proudly say this is one of the nicest s chassis' you will ever see or drive in the country. Although it doesn't have paint, it has been well taken care of and each typical problem on these cars has been addressed and fixed. It drives like a Lexus and never, never, never has left me stranded. After assembling the car I drove it for about 1 year without a single problem before upgrading the clutch and more upgrades. This car has never been to a drift event or a drag strip. It makes about 270 hp on a dyno dynamics @ 13.9 lbs, and gets about 260 miles to a tank flooring it around the city and 310+ on the hwy. It is a conservative tune that will allow the motor max life. There is not a single clip, bolt or nut missing on this car. Nothing rattles or vibrates. If not sold before I paint it, I have already purchased a gallon of Blue Raspberry Metallic which is one of the colors found on the 2013 Honda Fit. It is a bright teal that I absolutely love. Friend's of mine have bought $7200-$14,500 USDM 240's that have a hand full of "nice" parts but all of them have a years worth of problems if you don't find anything else wrong while diving in. You will not find a street car of this kind that needs less work. Located in Ga PM,call or text 770-714zero134 PRICE: $15,000 painted $12,500 unpainted $10,500 without wheels I DO NOT WANT TO TRADE! Chassis: 1995 Nissan silvia s14 base model (no sun roof and originally 4 lug) 126,000 KM on chassis Clean frame rails No water leaks Passes emissions with good cat Silvia grill Navan OEM front bumper with all grills Navan OEM side skirts Navan OEM rear valances Greddy rear wing New OEM Nissan euro glass head lights OEM Nissan corner lights with LED bulbs 6k or 8K HIDs All body panels are OEM metal New Circuit Sport LED red/clear tails Power folding mirrors New S14 OEM silvia window visors Has front fender liners Rear wheel wells have minor tub for wheel clearance Rear quarters have been rolled, flared and fiberteched for smooth finish I have front and rear Silvia emblems Suspension: BC coilovers Cusco rear camber arms Cusco rear toe arms Beefy front tension arms, Unknown brand but very nice, anodized green New OEM steering rack bushings New MOOG outer tie rods New OEM Nissan front lower control arms Brakes: 5 lug conversion 350z base model front brake calipers 350z slotted front rotors Hawk HPS pads front and rear Motul RBF600 brake fluid Stock lines on now, Have braided in basement New NAPA rear rotors Tucked brake lines under hood Wheels: Wed Sport TC 105N 1 owner 18x9.5 +12 in front 225/40/18 18x10.5 +10 in rear 245/40/18 Cheap daily beater tires only 2,000 miles max on them. No road noise and rides smooth Muteki black extended open face lugs Engine: S14 sr20det with 80,000 miles when purchased, 100,000 currently and rising everyday No leaks, no leaks, no leaks, no leaks New OEM valve cover gasket New OEM water pump New OEM rear main seal STI yellow top 550cc injectors No maf, converted to speed density with AEM EMS tuned by world class tuner Scott Seigel. Thick no name turbo manifold Stock s14 sr turbo New turbo gaskets Megan racing turbo elbow Megan racing down pipe New ISIS black turbo lines New OEM Nissan engine and trans mounts All new Gates drive belts (3) Motul 8100 engine oil OEM oil filter Shurken 10 lb battery Mishimoto big radiator Evans waterless coolant, they advertise you never have to change it for a life time Clean OEM over flow tank with no cracks Working A/C R134a Working P.S. / New Nissan fluid CX Racing intercooler kit black piping with front mount Oversized Greddy BOV with flange HKS oil cap Custom intake I made for turbo inlet painted wrinkle black, Aluminum Walbro fuel pump APEXI 3.5" cat back exhaust $1000 No name test pipe Drivetrain: SPEC clutch stage 2 with new throw out bearing and pilot bearing New 5 speed trans, last one was whining New blue blood racing gear oil in trans 75w90 Trans has zero leaks and shifts smooth C's short shifter Factory VLSD diff 4.08 ratio no leaks Motul 90PA mineral oil in diff New OEM diff bushings Factory silvia driveshaft of course Interior: All interior present except rear floor mats Auto up and down driver window Working hood, trunk and fuel door release cables All OEM Nissan glass Slick black dash with no air bag prevision. Apparently rare 350z steering wheel 350z base model front seat, Driver currently installed, will install pass side when time permits S15 rear seats Front silvia mats, Zenki not Kouki Original gauge cluster Digital climate control with AUTO Clean carpet New Sony double din radio, current top of line this year with mirror link, XM and nav Hands free and Iphone cable and Blue tooth New DB audio speakers front and back OEM turbo timer, HKS salesmen from Japan came to my former shop and loved it, took picture with JDM Iphone Coin holder PBM drift botton JDM flare hold with no flare Full trunk interior with wooden floor wrapped in carpet, factory cardboard just collapses. AEM UEGO wideband sensor I have lots of parts I can throw in for my asking price of sell separately. Up to the buyer. ARP head studs Solid trans mount HKS fuel rail Stainless braided brake lines More I'm forgetting As I own 5 cars and I'm a mechanic for a living I can not find time to do everything. This car does have the following problems. 1) fuel gauge is not accurate 2) the window tint should be replaced in my opinion 3) no horn 4) I would prefer cleaner door panels ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
