![]() Join Date: Oct 2002
What to do with EGR Canister Control Solenoid Valve Connector when removing emissions
I am attaching a drawing that shows everything that I am removing outlined in red. Removing everything is very straight forward because all you are dealing with are vacuum lines. However the EGR Canister Control Solenoid Valve and SCV Control Solenoid Valve both have electrical connectors coming from the wire harness. When I eliminate those two solenoid valves what should I do with the electrical connectors? Can I just tape then to the wire harness so they are out of the way or do I need to actually need to leave the solenoid valves and connect the wires to them but remove the vacuum lines?
I was hoping to remove the complete plate on the back of the cylinder head that those two solenoid valves are attached to. I have searched for this answer for about and hour and haven't found anyone making mention of the electrical connectors and what they did with them. Thanks, Zac |
![]() Join Date: Sep 2009
Trader Rating: (91)
![]() Feedback Score: 91 reviews
Just let them hang, ziptie, tape whatever.
www.monkeyboysyo.blogspot.com |
The wire harness/chassis/ECU is from a 93 hatch but I will be using a 95 KA24de along with the 95 intake manifold but I will be using the 93 fuel rail assembly to keep the original wire harness nice and neat. I will only be using vacuum for the fuel pressure regulator and brake booster, until I decide to go turbo.
Zac |
Trader Rating: (91)
No sir. Mine were disconnected for years when I was NA.
