Old 09-18-2012, 02:50 PM   #1
nicks13chandler
nicks13chandler is an unknown quantity at this point
starter turning but not cranking motor over.
so I got the starter issue figured out now when I go to turn the key I hear the starter spinning but the motor doesn't crank with it
Posted from Zilvia.net App for Android
nicks13chandler is offline   Reply With Quote
Old 09-18-2012, 03:24 PM   #2
stephens14sr
stephens14sr is an unknown quantity at this point
so, make sure your wiring is straight, then get a new starter........ jesus christ.
Full 2014 build progress www.handicapmafia.wordpress.com
stephens14sr is offline   Reply With Quote
Old 09-18-2012, 03:40 PM   #3
xptnike
xptnike is an unknown quantity at this point
had a similar issue a while back, possible that the gear wheel on the starter is loose. although the starter itself is working/spinning, the gear wheel with the teeth that inserts onto the flywheel teeth may have somehow gotten loose/broke and isn't spinning along with the starter. I had to get a new starter...damn cheap ass autozone pos starters...good thing for the lifetime warranty, let me know if that's what happened to your starter
xptnike is offline   Reply With Quote
Old 09-18-2012, 03:45 PM   #4
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Try a new solenoid on it.
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 09-18-2012, 04:18 PM   #5
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
^ solenoid is shot. take it off and test the starter. if the solenoid isn't working the starter will spin but not engage
godsmack is offline   Reply With Quote
Old 09-18-2012, 05:58 PM   #6
ZenKi_373
ZenKi_373's Avatar
ZenKi_373 is an unknown quantity at this point
have someone outside with a pipe and a hammer hit the starter repeatedly while you crank the motor. if it turns on...well use common sense from here
ZenKi_373 is offline   Reply With Quote
