Old 12-19-2001, 05:29 PM   #1
240booster
240booster is an unknown quantity at this point
Ok so i searched the topics on this board and read the topic in FAQ at 240sx.org on cutting the yellow wire with a green stripe at the ECU to kill the speed limiter. So i get in there and cut the yellow wire with the green stripe. Take it for a spin, I try out all the electrical stuff it all works ....... &nbsp;BUT MY CHECK ENGINE LIGHT IS ON!! I though o shit but the engine was running fine and nothing noticeable so i continued on. Got on the interstate AND TOPPED OUT AT 118!!!!!!! &nbsp;GGGRRRRRRRR &nbsp; &gt;:-( &nbsp; So i got back and started clamping that wire back together and then I NOTICED THERE WAS ANOTHER YELLOW WIRE WITH A GREEN STRIPE!!!!!! The one i cut has one single silver dot every inch and the other one has 2 silver dots every inch. Neway, so i repaired the 1st one i cut and then tried the 2nd one ...... IT WORKED!! But my check engine light is still on!!! WHAT THE #### HAVE I DONE!!!! HELP??!!! does neone have a wiring diagram that can tell me what i cut and if i did ne damage or not?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> &nbsp; THANKS IN ADVANCE.
240booster is offline   Reply With Quote
Old 12-19-2001, 07:01 PM   #2
craigs13
craigs13 is an unknown quantity at this point
so by cutting that wir your speed limiter is now off?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>??? how and where do i start.
craigs13 is offline   Reply With Quote
Old 12-19-2001, 07:14 PM   #3
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
You should try resetting the ECU. I think it'll keep error messages is memory until reset or run for a while.
I'm not positive how, but I think just disconnecting the battery for some time will do it if you dont know a mechanic w/ the equipment to do it properly.
greg
gfisch is offline   Reply With Quote
Old 12-19-2001, 07:31 PM   #4
Arcane
Arcane is an unknown quantity at this point
to reset the ECU...just disconnect the battery for 2 hours...about 95% sure on this....someone will correct me if i'm wrong....
Arcane is offline   Reply With Quote
Old 12-20-2001, 12:58 AM   #5
240booster
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from craigs13 on 9<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>1 pm on Dec. 19, 2001
</td></tr></table><span id='postcolor'>
Ya u gotta cut the yellow wire with the green stripe and 2 silver dots .... and im not really sure what u mean by how and where to start?? i guess ur asking where to cut?? that doesn't matter i just sniped it and taped up the ends then tapped them together.
Kewl thanks im installing my header tomorrow i will unplug the battery then ..... but what im still wondering is the 1st wire i cut WHAT DOES IT DO?? wondering if i FU@#ED nething up?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
O and now my 5th gear rev limiter is holding me back when i get to about 125mph the rev limiter kicks in .... but lol i guess i will be satisfied with 125 for a little while &nbsp; ....... &nbsp; also for the 1st time i actually felt unsure about my 240 handling tonight when i hit a bumpy spot on the interstate at 125, it started bouncing around kinda scared me a little :-D
(Edited by 240booster at 3<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>4 am on Dec. 20, 2001)
Old 12-20-2001, 09:05 AM   #6
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
if you have a SOHC and you cut the wire, it will lower your top speed to 90. it happened to me, but i switched it back.
whateverjames is offline   Reply With Quote
Old 12-20-2001, 01:37 PM   #7
craigs13
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from 240booster on 12:58 am on Dec. 20, 2001
O and now my 5th gear rev limiter is holding me back when i get to about 125mph the rev limiter kicks in .... but lol i guess i will be satisfied with 125 for a little while ....... also for the 1st time i actually felt unsure about my 240 handling tonight when i hit a bumpy spot on the interstate at 125, it started bouncing around kinda scared me a little :-D
</td></tr></table><span id='postcolor'> cool i am glad to see it worked..... now on 240sx.org i saww something about that you had to reset your computer when you do this!?!? I have never tried this so can you clarify that part for me.. thanks... next step get rid of that #### rev limiter and take her up to 136...
Old 12-21-2001, 01:15 AM   #8
240booster
No u don't have to reset ur computer. U see i cut the wrong wire the 1st time i did it. That made the check engine light come on and the peeps were telling me to reset my ECU by unplugging the battery for a couple of hours and it should probably turn the check engine light off ...... wellll i did that today and it didn't work so i don't know what to do know guess i take it to Nissan.
Old 12-21-2001, 08:23 AM   #9
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
To reset the ecu you have to turn the screw on the back of the ECU to the testing position read the code and then put it back to the normal possition. Full details on this are on 240sx.org's FAQ. It some times takes a few tries. The disconnect the batery stuff is bunk and not necessary.
uuninja is offline   Reply With Quote
Old 12-21-2001, 03:53 PM   #10
S13 Passion
S13 Passion is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from 240booster on 1:15 am on Dec. 21, 2001
are you crazy?? &nbsp;take it to Nissan? &nbsp;wouldnt they find out that you were trying to disconnect the rev limiter? or would you just try to play dumb and say you didnt know anything abou it?
S13 Passion is offline   Reply With Quote
Old 12-21-2001, 04:06 PM   #11
S13 Passion
oh, btw... where is the ECU on the 240? &nbsp;is it at the bottom of the passengers side (below glove compartment)?
Old 12-22-2001, 02:27 AM   #12
240booster
Ya it's in the kick panel on the passenger side ...... and who cares if they find out just as long as they fix the #### thing it's my car out of warranty i can do whatever i want to it, not like im asking them to fix it for free :-)
