Old 10-26-2012, 07:15 AM   #1
GL Chrillz
GL Chrillz's Avatar
GL Chrillz is an unknown quantity at this point
solid motor mount question
I just swapped my sr20 to another s13 shell, and while it was out i took my motor mounts in to school and welded some plate steel to them to make them solid since they were worn to hell and it's going to be a track car. i just put the motor in last night, and since the mounts have no give anymore, the trans mount is off slightly. the trans lines up perfectly, just the mount is off...is there any problem with me removing the rubber off the trans mount, lining that up and making it solid as well and calling it a day?
GL Chrillz is offline   Reply With Quote
Old 10-26-2012, 07:25 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Solid mounts on a 4 banger...baaaaaaaad idea.
CLICK HERE!!!
Old 10-26-2012, 07:38 AM   #3
ForeignMuscle
ForeignMuscle is an unknown quantity at this point
You will regret this big time, but if you want, I will sell you my Delrin poly solid mounts that actually line up. You can have them for $20 if you want. You WILL regret this, guaranteed. I wouldn't have solids on a race car much less a street car. It was embarrassing it was so bad. My girlfriend wouldn't ride in it, people at red lights could hear it vibrating. Do what you do though. You have been warned.
ForeignMuscle is offline   Reply With Quote
Old 10-26-2012, 08:03 AM   #4
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
You took solid mounts to another level, your one crazy dude.
Pinggg is offline   Reply With Quote
Old 10-26-2012, 08:07 AM   #5
Chaluska
im with everyone else.. i had solid mounts like 3 years ago, the vibrations were so bad, after about a week, everything in my car was rattling and squeeking so bad, it sounded like a mouse orgy in a tin can.
id never recommend solid mounts ever on a 4 cylinder unless it was completely balanced, and was race only.
Old 10-26-2012, 08:13 AM   #6
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
urethane mount r the way to go,you'll have some vibration but you fillings or car wont fall apart
project-D180 is offline   Reply With Quote
Old 10-26-2012, 08:52 AM   #7
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
I had solid mounts once, on my ka. Yeah that lasted a day lol
Old 10-26-2012, 09:52 AM   #8
GL Chrillz
GL Chrillz's Avatar
they're really that bad? it's definitely not going to be a daily driver at all.
Old 10-26-2012, 10:06 AM   #9
living4surf
Trader Rating: (52)
living4surf is an unknown quantity at this point
Feedback Score: 52 reviews
i dont find my solid metal mounts that bad i dont recommend it for a daily but for just a weekend fun car or the track i love the solid feel they give you
living4surf is offline   Reply With Quote
Old 10-26-2012, 10:11 AM   #10
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
It really depends on preference. I had a friend who tracked his DD and had solid mounts, he didn't mind it but I never liked riding in his car anywhere.
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 10-26-2012, 11:03 AM   #11
GL Chrillz
GL Chrillz's Avatar
I might drive it to school once in a while or something just to work on it, show some buddies, etc. but mostly it's going to be tracked. I got the same response about solid subframe risers and how they ride horribly. i dailied on those and a welded diff for 6 months on michigan roads slammed and didn't bother me...guess i'll see how it feels maybe get some oem mounts to keep as spares. back to the question, can i just cut out the rubber on the trans mount, line it up and weld it together? as long as the trans is lined up it should be good to go right?
Old 10-26-2012, 11:08 AM   #12
ForeignMuscle
People I know don't even race with them. Your engine needs movement and shock absorbing will happen in other areas if not in your mounts. Ie: your axles, driveshaft, your ass bone, etc..
Old 10-26-2012, 11:21 AM   #13
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
I have had solid mounts in a few cars.. Even with the solid urethane bushings sucked. IMO its not for me. track or daily. I ended up buying just used oem motor mounts. and I agree with ForeignMuscle , the vibrations will go everywhere. My dash would vibrate so loud I couldn't think at lights. but I guess if racecar -_-'
HS13KLS is offline   Reply With Quote
Old 10-26-2012, 01:31 PM   #14
GL Chrillz
GL Chrillz's Avatar
didn't really think of it that way. I guess i'll get the car running and try and find some OEM ones >.>
Old 10-26-2012, 01:47 PM   #15
GL Chrillz
GL Chrillz's Avatar
ok this is a really "backyard bob auto" question here, but can you cheap out and use hockey pucks as a motor mount? i see some people talking about it with a little googling, and i'm sure i have a ton of hockey pucks laying around. this would be about the same as a poly mount right?
Old 10-26-2012, 04:45 PM   #16
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
Yes, its the best route actually. Hockey Pucks are vulcanized rubber, its a bit stiffer than polly but if you do it right they work great and will last longer.
Here is what most poly's look like -
And the Hockey's -
The only problem is, you are going to what 2.5" motor mounts for a stock Nissan engine (SR/KA/CA). Pucks are 1". So either cut one in half (not recommended) or get some sort of metal spacer. I believe my friend just stacked some thick ass fender washers in the center. $8 for the pucks and hardware.
Corbic is offline   Reply With Quote
Old 10-26-2012, 04:49 PM   #17
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
I usually don't cry foul when it is obvious that someone hasn't searched, but you need to search a little harder on this. I know there are allot of extra hockey pucks around these days... but you have much less canadian-ghetto options out there.
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 10-26-2012, 04:52 PM   #18
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
You can use OEM Z32 motor mounts.
They fit the same as S-chassis mounts yet will be stiffer since they are made for a heavier motor. Plus they are less bulky.
Megan offers an even harder version, but they are very overpriced.
Old 10-26-2012, 04:57 PM   #19
ForeignMuscle
I have a set of polys just like the red ones posted... $20 and I'll ship them to you. You were warned though.
Old 10-27-2012, 01:09 AM   #20
280zx2by2
280zx2by2's Avatar
280zx2by2 is an unknown quantity at this point
I have poly Cusco's on my daily driver, I have almost no motor movement and I love the feel.
Never rode in a 240sx with solids but I have rode in an EF civic with them and it rattled your ass hairs to the point of you having to lift your rear out of the seat to avoid the tickle fight you were having with the engine.
280zx2by2 is offline   Reply With Quote
Old 10-27-2012, 02:09 AM   #21
jamg
jamg is an unknown quantity at this point
here's a quick fix.
i put that stuff all over my stock mounts. it should hold up.
jamg is offline   Reply With Quote
Old 10-27-2012, 07:09 AM   #22
GL Chrillz
GL Chrillz's Avatar
pm me pics
Old 10-27-2012, 09:39 AM   #23
ForeignMuscle
Used for maybe 100 miles.
Old 10-27-2012, 01:08 PM   #24
GL Chrillz
GL Chrillz's Avatar
wow they look brand new...20 bucks? might as well do that. PM me your paypal
Old 10-27-2012, 03:06 PM   #25
ForeignMuscle
You'll need to buy another bolt. I bought them at a hardware store so no biggie. The mounts are brand new though. I have no need for them.
Old 10-27-2012, 03:28 PM   #26
CaptainVlad
CaptainVlad's Avatar
CaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really nice
Idk why everyone always complains about solid mounts...
I have the Avid mounts, which are solid, but have a small piece of rubber in them. (which I doubt do anything) With solid mounts motor/trans mounts, solid subframe mounts, and a weld in roll cage, it vibrates as you would expect, but it's not bad at all....Granted my car is not a daily driver, but still...
CaptainVlad is offline   Reply With Quote
Old 10-27-2012, 03:38 PM   #27
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
so im not stepping on toes here, whoever has another set - i believe there were 2 sets offered in this thread - ill buy the set he doesnt. just pm the paypal and its done.
thanks!
AsleepAltima is offline   Reply With Quote
Old 10-27-2012, 05:01 PM   #28
BRAIN_Z33
BRAIN_Z33's Avatar
BRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfection
Drift freaq mounts.
End thread
BRAIN_Z33 is offline   Reply With Quote
Old 10-27-2012, 05:47 PM   #29
fliprayzin240sx
I got a used set of URAS Engine mounts...still stiffer than anything I've used before new and wont rattle your windshield off. Check my thread in my sig if you wanna check it out.
CLICK HERE!!!
Old 10-28-2012, 02:57 AM   #30
stev0n
stev0n's Avatar
stev0n is an unknown quantity at this point
Ny nephew's RB'd hatch has solid motor mounts and it feels very similar to my old stock s13 with stock mounts. Is it as smooth as my granny car (mercury sable)? well fuck no. But i don't think it rides bad at all & it's his DD. Especially not as terribly as others feel about solid mounts.
I've got solid mounts in my LS s13 because they were $100 cheaper than the poly counterpart. But I haven't driven it yet.
stev0n is offline   Reply With Quote
