Old 11-03-2012, 07:54 PM   #1
240low
240low is an unknown quantity at this point
Timing Fluctuation please help
ok, i have been trying to fix my car for about 2 weeks. when i try changing my timing.. unplugging the tps yada yada.. i know the routine.. it makes my timing change so say i set it to 20 degrees.. i turn the car off reconect. start car and check timing it goes to 0 degrees.
tps reads .45.
cleaned out the iacv..
pulled codes got crank position sensor.. replaced my distributor since thats where its located on ka24de motors.
and my timing is still all whack..
maybe bad wiring in the cps?
bad iacv?
any help would be appreciated... i dont want ppl telling me to search first cuz trust me i have been non stop researching about it.
Update: pulled codes got air flow meter circuit.. Wiped the code didn't come back.. Now after driving the Ecu reads 55 no malfunction.. But still not operating how it should
240low is offline   Reply With Quote
Old 11-03-2012, 08:03 PM   #2
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
OBD 2 ka24de have a crank angle sensor on the bell housing.
rcdad123 is offline   Reply With Quote
Old 11-03-2012, 08:05 PM   #3
240low
its a 92 it doesnt have obd II
Old 11-03-2012, 10:25 PM   #4
Kingtal0n
Kingtal0n's Avatar
try a different timing light, and make sure the direction of the pickup on the plug wire is correct, most timing lights will read different depending on the orientation of the pickup.
tinyurl.com/4l80er
Old 11-04-2012, 01:53 AM   #5
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Don't bother checking timing with the TPS connected, they have you disconnect it for a reason to set timing. If it was going to be the same when plugged in there would be no reason to unplug it.
As for the codes IDK but your chasing ghosts with the timing.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 11-04-2012, 09:20 AM   #6
240low
well i know the timing light works fine cuz it works fine on my friends 240. its his light. and the problem is if i set it to 20 degrees with tps off.. which is hard sometimes cuz my idle keeps fluctuating making it go from like 18 degrees to 24 degrees. and if i go to get it smogged you shouldnt have to disconnect the tps to read the timing. so although its set at 20 with it disconnected when the smog guy goes to check it, it will read 0
Old 11-04-2012, 04:05 PM   #7
zerodameaon
Your smog guy is not doing it right, every check I have had done they always have unplugged it, and that was per the instructions they have in their book.
Old 11-04-2012, 04:10 PM   #8
240low
Well the two ppl I went to said it shouldn't make a difference, I even checked my friends 240 with the tps connected and it read 20 degrees..
Old 11-04-2012, 04:17 PM   #9
240low
Also, when I clamp the iacv hose it drops idle a lot. That's what it should be doin right?
Old 11-10-2012, 06:03 PM   #10
240low
bump!!!!!!!!!!
Old 11-11-2012, 04:03 PM   #11
Croustibat
*unplug IACV*, not clamp the hose. Nor open the hose. Electrically disconnect it.
Your timing should not change at idle between 800 and at least 1500, so you can try to set it higher.
