Old 11-22-2012, 07:27 PM   #1
GripSpec
GripSpec's Avatar
GripSpec is an unknown quantity at this point
Gauge Wiring: Does this look ok?
Wiring up 3 electrical autometer gauges. I suck at wiring so I want to make sure this looks semi legit. A couple questions:
-is it ok to splice all three guages into one wire and then splice that wire into the ACC power wire and ground wire as shown in the diagram?
-is it ok to splice the illumination blub wires into these 2 wires as well?
-The cigarette lighter wires look to be either 16-18 guage. Will these wires be able to withstand powering the gauge and illumination bulb for all 3 gauges?
If this setup looks completely retarded, please give me some opinions on possible changes.
GripSpec is offline   Reply With Quote
Old 11-22-2012, 07:40 PM   #2
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
Everything you have done is ok and I have done something similar to this myself. I didnt tap into the cig lighter however but as long as you have a solid ground then you'll be fine. You should wire the illlumination to a switch on source, tap around with a test light in the wires beneath the column shroud and you'll find a headlamp wire to tap into.
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 11-23-2012, 10:42 AM   #3
Sthirteen90
Sthirteen90 is an unknown quantity at this point
im not sure how many amps is going to the cig lighter. but if its enough to support all three guages and the lighter then youll be okay. i dont feel like i is though.
Sthirteen90 is offline   Reply With Quote
Old 11-23-2012, 10:49 AM   #4
silviaks2nr
silviaks2nr's Avatar
I wouldn't use the cigarette lighter. Use an ignition switched +12v from the stereo wiring and make your own ground to the radio bracket instead.
Old 11-23-2012, 11:33 AM   #5
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
If I remember correctly the auto meter gauges called for a 1amP fuse... So add one
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
