Old 11-22-2012, 10:18 AM   #1
goldendrift
goldendrift is an unknown quantity at this point
Rb20det misfire and smell gas!!!
i have a stock rb20 in a s14 and i just got it tuned last week and wireing issue fixed. so i started noticing that at low speeds the car would misfire, got worse and worse. now i smell gas from exaust and it misfires and horriable ide. anyone with ideas?
goldendrift is offline   Reply With Quote
Old 11-22-2012, 10:54 AM   #2
K3MPS
K3MPS is an unknown quantity at this point
check coil packs and injectors
K3MPS is offline   Reply With Quote
Old 11-22-2012, 12:06 PM   #3
stamps31757
stamps31757's Avatar
stamps31757 is an unknown quantity at this point
check to see if the plugs are gapped correctly. If its been a while since they have been replaced i would recommend changing them. Its cheap and easy. Most of the problems i get from people that bring their RB to me is improperly gapped plugs. also check to see if you have any leaks in the vacuum system.
stamps31757 is offline   Reply With Quote
Old 11-22-2012, 01:44 PM   #4
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
The problem is that it's an RB20.
omgRWDgoodness! is offline   Reply With Quote
Old 11-22-2012, 02:19 PM   #5
stamps31757
If your not gonna try to help the guy there is no reason for you to post in here. He is just asking for help.
Old 11-22-2012, 02:20 PM   #6
trickey1991
trickey1991 is an unknown quantity at this point
i had same problem, mine got worse. it ended up being the coilpack harness. got one from wiring specialties for like$60
92' R32 GTS-T 355whp
trickey1991 is offline   Reply With Quote
Old 11-24-2012, 03:16 PM   #7
goldendrift
Yea is was the coil pack, it overheated, i guess that is a comon problem and im scared to buy another one for 80$ and it burn up again. What is the cause of that? so i can avoid that happening again.
Old 11-24-2012, 03:32 PM   #8
goldendrift
This is it. and if anyone has one i will buy.
Old 11-24-2012, 03:56 PM   #9
stamps31757
thats a coil pack. I would check with rawbrokerage to see if they have one. They are more than likely going to have it. They deal with RBs
Old 11-24-2012, 04:57 PM   #10
trickey1991
It's prob the harness swap it out they're like 50-60 new and save alotta headache . I burned thru 3 coil packs on diff cyl sets then I changed the harness n it's perf
Old 11-25-2012, 07:58 PM   #11
goldendrift
Ordered one, and I'm looking for harness don't want this sh** to happen again, thanks for the help much appreciated.
Old 11-25-2012, 08:17 PM   #12
trickey1991
RB20DET Coilpack Wiring Harness | Wiring Specialties
Old 11-25-2012, 08:59 PM   #13
wslugantz
wslugantz's Avatar
wslugantz is an unknown quantity at this point
you might also want to check the ignitor. the stock ones on rb20's are just. you could replace it with one from a turbo 300zx.
wslugantz is offline   Reply With Quote
misfire, problems, rb20
