Old 11-09-2012, 12:54 PM   #1
turkey
turkey's Avatar
turkey is an unknown quantity at this point
s13 s13 hatch,silvia front,built sr20det partout
unfortunatly the time has come to part her out, WAY TO MANY LOWBALLERS and i have to get my moneys worth out of her so here we go
CAR IS LOCATED IN LOMPOC CALIFORNIA ZIP CODE 93436
Silvia front with clean as fuck bricks (not one scratch not one broken tab 100%perfect) carbon fiber hood,oem metal fenders,silvia grill not gtr and circit sport corner lights (will not part out seperate wanna sell as complete front)$$$$1200$$$$$
fully built sr20det,heres the specss
Fully Built Redtop SR2(1)Det
Engine Built at Pit Garage with ONLY 9000 miles on all engine internals. All machine work done at R.S. Machine(Largest Race and Performance Engine machine shop in southern California)
Fully Built Shortblock Information:
Redtop SR20det Shotblock bored out .020 over
MAHLE 86.5mm Forged Pistons // 8.5:1 Compression Ratio
Forged Eagle Rods
Brand New ACL STD Size Race Rod Bearings
Brand New ACL STD Size Main Bearings
Brand New OEM Thrust Bearings
Micropolished Crankshaft
Brand New OEM SR20DET Oil Pump(Decked with Block to Ensure correct height): Oil Pressure with 10-40w Mobil 1 Synthetic: 70 psi at 3300+ RPM, and 20+ Psi at 800 RPM idle. HEALTHY ENGINE
Brand New OEM S14 Water Pump
Brand New OEM S14 Oil Pump pickup
Brand New OEM Rear Main Seal
SR20Det Built Head Information:
Sr20det Redtop Head Hot tanked and decked
Fully reconditioned
Brand New ARP Reinforced Head Studs
Brand New Supertech Valve Guides
Brand New Supertech Valve Stem Seals
Brand New BC Titanium Springs
Brand New BC Titanium Retainers
Brand New Tomei Rocker Arm Stoppers
Brand new Cosworth 1.5mm Headgasket (lower compression/more boost)
Brand New OEM Timing chain kit
Blows NO SMOKE, Doesn't burn Oil.
Compression tested at : 148,145,149,144, which is awesome for having a 1.5mm headgasket on 8.5:1 Compression ratio. This engine was broken in for 1,500 miles with dino oil, and lots of decel in vacuum.
Vacuum sits at -20 in/hg at 800 RPM idle.
Power Upgrades/Tuning:
S14 T28 Ball Bearing turbo
Stance Clocking adapter
DIF Stainless Steel Turbo Lines
550cc Denso Injectors tested at RC Engineering
Z32 N62 Maf
Z32 Blitz SUS Metal Intake Filtration System
Enthalpy DUAL Tuned ECU. First tune is current setup/second is 740cc/2871r
Brand New OEM Fuel Rail
Brand New Tomioka Adjustable Fuel Pressure Regulator with FP Gauge
Deatschwerks Fuel Pump Hardwire kit to ensure optimum Fuel Pressure
Engine Misc:
Greddy Type RZ Blowoff Valve(Recirculated)
CX Racing FMIC Kit with tapped nipple for Wastegate
Omori Oil Filter Relocation Kit(Takes larger Toyota Supra Oil Filter)
Walbro 255 LPH Hi Flow pump(with Fuel Pump Hardwire kit)
Z32 TT OEM Fuel filter
New OEM Oil Pan
Megan V2 Short Shifter(No Rattles)
Megan Racing 3 inch Turbo Elbow
3 inch Downpipe
3 Inch Circuit Sports test pipe
3.5 inch Kakimoto Exhaust (SUPER DEEP)
Transmission:
6 Puck SPRUNG ACT HD Clutch Kit
Brand New Clutch Master Cylinder with Lifetime Warranty
NEW TOB
New Pilot Bearing
New Transmission Front Cover
Resurfaced flywheel
Electronics:
Innovate MTX-L Wideband with Datalogging software
AC 7 Autotechnic Electronic Oil Pressure Gauge
Limited Edition Spearco Boost Gauge
Pioneer CD Player
price 4k obo
Enjuku Racing Isis HR Coilovers
375$$
XXR 530 17x9.75
brand new less than 150 miles on them good decent tread left
looking to get what i spent on the wheels back
700$$
JDM 180sx 4.3 Gearing VLSD with axles
250$$
rolling shell
1200$$
if you have any other questions feel free to contact me in p.m. or through text and also please bump my thread
my number is 805-757-2579
for pics and other questionsss
thanks for looking guys
turkey is offline   Reply With Quote
Old 11-10-2012, 12:15 PM   #2
turkey
turkey's Avatar
bump this bitch to the top come on peopleee
Old 11-10-2012, 01:25 PM   #3
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
whys that front end so jacked up?
Old 11-10-2012, 07:20 PM   #4
scumbag
scumbag's Avatar
scumbag is an unknown quantity at this point
how much for he boost gauge?
scumbag is offline   Reply With Quote
Old 11-10-2012, 10:06 PM   #5
xErniexChaosx
xErniexChaosx's Avatar
xErniexChaosx is an unknown quantity at this point
I second that!
xErniexChaosx is offline   Reply With Quote
Old 11-10-2012, 10:15 PM   #6
chaosxsteve
chaosxsteve is an unknown quantity at this point
How much for 5 speed swap?
chaosxsteve is offline   Reply With Quote
Old 11-11-2012, 12:13 AM   #7
DripRipper
DripRipper is an unknown quantity at this point
Are you willing to sell the front coilovers only?
DripRipper is offline   Reply With Quote
Old 11-11-2012, 12:22 AM   #8
Frankiegamer
Frankiegamer is an unknown quantity at this point
yeah man that front end looks like the front of my asss lol GLWS
Frankiegamer is offline   Reply With Quote
Old 11-11-2012, 01:28 AM   #9
blackdragon328
blackdragon328 is an unknown quantity at this point
if you get no interest i'm looking for the fenders and the hood (as long as its not as bent as that pic makes it seem).
hit me up if you end up parting it out
blackdragon328 is offline   Reply With Quote
Old 11-11-2012, 12:45 PM   #10
turkey
turkey's Avatar
to asnwer your guys question the hood is a lil bent other than that everything needs to be realigned better (ziptied on) thats why everything looks so fucked up!
want to sell full swap dont wanna part out tranny!
and shoot me an offer on the boost gauge
Old 11-11-2012, 12:51 PM   #11
Nismo11
Nismo11 is an unknown quantity at this point
good stuff, glws! i need the bricks!
Nismo11 is offline   Reply With Quote
Old 11-12-2012, 06:36 PM   #12
andrew600
ill tongue punch her fart box
andrew600's Avatar
andrew600 is an unknown quantity at this point
i need driver side fender!
if you will split let me know by friday. if not im buying off ebay.
andrew600 is offline   Reply With Quote
Old 11-15-2012, 12:16 PM   #13
brandon19761
brandon19761 is an unknown quantity at this point
VLSD 5, or 6 bolt? ABS, or non ABS?
Thanks.
'95 S14 KA24det, '96 Z32tt, '93Z32tt, '93 Z32 NA slicktop!!
brandon19761 is offline   Reply With Quote
Old 11-15-2012, 12:52 PM   #14
JC831
JC831's Avatar
JC831 is making a name for him/her selfJC831 is making a name for him/her self
Doors? Hood? Pm me
JC831 is offline   Reply With Quote
Old 11-15-2012, 02:36 PM   #15
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
Pics of the innovate wideband and how much shipped to 89460.
Sr22 in the works
slow92 is offline   Reply With Quote
Old 11-15-2012, 07:24 PM   #16
kevinintegra
kevinintegra is an unknown quantity at this point
Will you sell and ship the bricks?
If so text me 208-353-7408
kevinintegra is offline   Reply With Quote
Old 11-15-2012, 07:48 PM   #17
thizzen4
Trader Rating: (22)
thizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymore
Feedback Score: 22 reviews
pm me price on the wide band if willing to part and sale it thankx
thizzen4 is offline   Reply With Quote
Old 11-15-2012, 08:52 PM   #18
NJs13_1993
NJs13_1993's Avatar
NJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of lightNJs13_1993 is a glorious beacon of light
possibly interested in the coilovers. price shipped to 08016?
Originally Posted by hellion240sx View Post
Zilvians gonna zilvia...
NJs13_1993 is offline   Reply With Quote
Old 11-27-2012, 08:17 PM   #19
zneubauer
zneubauer's Avatar
zneubauer is an unknown quantity at this point
how much for the fpr?
zneubauer is offline   Reply With Quote
Old 11-28-2012, 02:47 PM   #20
jcreative187
jcreative187's Avatar
jcreative187 is an unknown quantity at this point
are u willing to trade your coilovers?
jcreative187 is offline   Reply With Quote
Old 11-28-2012, 02:55 PM   #21
andrew600
andrew600's Avatar
I don't think he is willing to do anything. Last post was over two weeks ago.
Let this one die.
Old 11-28-2012, 03:26 PM   #22
turkey
turkey's Avatar
p.m me for any questions all p.m's were replied!
