Old 11-29-2012, 02:04 PM   #1
RocketOgre
RocketOgre's Avatar
RocketOgre is an unknown quantity at this point
Miss-fire after increasing the boost. Solution?
I recently fixed a long-standing wastegate issue with my GT2871R. The HKS actuator was letting the flap open no matter the signal from the vacuum line. I got a Forged actuator and I couldn't be happier. So I just went from 12psi to 19psi and have fallen in love with my motor all over again. One problem I'm getting occasional miss-fires under full-throttle only after hitting boost, usually if I start the pull at a low rpm.
I've got a JWT ECU so she runs a bit rich, AFC neo is in the works. I've got a stone stock ignition system heat range 7 NGKs and all the NGKs are probably 10k miles old. My question is this: Do I need an ignition amplifier at that boost range or should a new set of plugs fix the problem? Could how rich the JWT let's it run have something to do with it?
'89 hatch DD'd SR'd 2871'd - Sold
2006 Legacy GT Wagon
RocketOgre is offline   Reply With Quote
Old 11-29-2012, 02:15 PM   #2
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
re gap the plugs down lower to .28 or so and try it again, it wouldnt hurt to change the plugs but a regap should fix the issue
Grenade180sx is offline   Reply With Quote
Old 11-30-2012, 02:01 PM   #3
RocketOgre
RocketOgre's Avatar
Gapped them down and the problem is fixed, thank you sir.
Old 11-30-2012, 04:50 PM   #4
Croustibat
You need a remap too. Smaller gap is mandatory, but going from 12 to 19 psi without remapping is dangerous (and i mean it, no AFR piggyback shit here, if you dont want to melt your pistons you need to pull timing)
Old 11-30-2012, 10:24 PM   #5
RocketOgre
RocketOgre's Avatar
Which part of my post makes you think I'd have heavily advanced timing? Also melting pistons would involve going lean, I'm running rich and my only real danger would be detonation, which shatters pistons.
