Old 12-01-2012, 02:09 PM   #1
iLOVEASIANGIRLSS
iLOVEASIANGIRLSS is an unknown quantity at this point
s14 gas tank issue
so i bought a used gas tank off the forum here, the guy says the gas tank is off a 96, my car is a 95. so i tired to install the gas tank to my car but one of the fuel pump sensor on the tank wont connect to the sensor on the chassis. to my knowledge i thought at least 95-96 parts were compatible with eachother. my orignal gas tank had a crack so im in the process of replacing it. anyone know why i ran into this problem? ive searched for answers or at least some information but im getting really frustrated now any help or advice would be great
Pearl White 95 base S14
iLOVEASIANGIRLSS is offline   Reply With Quote
Old 12-01-2012, 02:19 PM   #2
iLOVEASIANGIRLSS
"FYI: The fuel level sender on the 95 (Pre-OBDII) has 3 pins out, and the 96+ (OBDII) has 4 pins out.
I haven't downloaded the '96 FSM to see what the testing procedure is, but just probing each of the 4 pins with an ohmmeter shows that the resistance changes when the float is at different positions. I suspect that it works, but I can't verify it yet. I'm not sure if you could use a 96+ fuel sender in a '95 tank or not. Physically, I believe that they're the same, so all of the brackets will fit. The only concern is if you can drop one of the wires/remove it and still use it.
If anyone needs a '96 fuel level sender, get in contact with me and we'll work out a price and I'll verify that it works."
i searched a little harder and found this, this is the problem i encountered, is there any way to use the 96 OBDII tank on my 95 s14?
Old 12-02-2012, 08:50 PM   #3
iLOVEASIANGIRLSS
Anyone know ??
Old 12-03-2012, 06:57 AM   #4
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
had my tank changed since it was leaking too and my fuel gauge is off too real big annoyance with me. I haven't taken a look in the tank yet since I have been working on other things.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 12-03-2012, 10:07 AM   #5
iLOVEASIANGIRLSS
Seriously such a pain in the A**
Old 12-05-2012, 03:59 PM   #6
Promise Land
Promise Land's Avatar
Promise Land is an unknown quantity at this point
just re-pin the connector to match between the model years. I have a '96 tank on miy '95 (OBD-1) car and had to re-pin mine to work. Use the different service manuals between the model years and it's easy to figure out which goes to which.
Promise Land is offline   Reply With Quote
