Old 12-27-2012, 10:47 PM   #1
Tiffanythe240
Tiffanythe240 is an unknown quantity at this point
"BRAKE" light on constantly
Hey guys, in my S14,the BRAKE light illuminated at all times, even when the ebrake is down and my brake fluid is at level and has full pressure, it happens up until ill shut my car off after a 20 minute drive then start it back up, or if i slide a corner....any insight on what it might be?
PS-the EBrake doesnt lock my rear wheels anymore like it used to and the cable is tight
Tiffanythe240 is offline   Reply With Quote
Old 12-27-2012, 11:03 PM   #2
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
Its probably the low brake fluid sensor.
rwtf is offline   Reply With Quote
Old 12-27-2012, 11:04 PM   #3
DoobieS13
DoobieS13's Avatar
DoobieS13 is an unknown quantity at this point
you mean this one??
Doobie
DoobieS13 is offline   Reply With Quote
Old 12-27-2012, 11:13 PM   #4
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
How much life is left in your brake pads themselves? Might want to check those as well.
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
Old 12-27-2012, 11:49 PM   #5
snofufu
snofufu's Avatar
snofufu is an unknown quantity at this point
Your alternator might be going bad.
snofufu is offline   Reply With Quote
Old 12-27-2012, 11:52 PM   #6
Jason9011
Jason9011 is an unknown quantity at this point
The battery light would come on if the alternator was bad.....
Jason9011 is offline   Reply With Quote
Old 12-27-2012, 11:58 PM   #7
No 240.. No id
No 240.. No id's Avatar
No 240.. No id is on a distinguished road
Your rear brake pads!! Had the same problem while back
No 240.. No id is offline   Reply With Quote
Old 12-28-2012, 12:02 AM   #8
snofufu
snofufu's Avatar
its a possibility if brake and battery are on it could be the alternator
Old 12-31-2012, 06:29 PM   #9
Tiffanythe240
ill check my rear brake pads, but it only really happens when the cars cold, after its 100percent warm, its normal?
Old 12-31-2012, 09:13 PM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Reservoir full? Brake pedal grommet still there? E-brake switch toggling?
CLICK HERE!!!
Old 12-31-2012, 11:47 PM   #11
stamps31757
stamps31757's Avatar
stamps31757 is an unknown quantity at this point
adjustment on the ebrake handle is also an option. the ebrake switch could be stuck in the wrong position. there are many different reasons for the light to be on. Without us being there we can not diagnose the problem properly.
stamps31757 is offline   Reply With Quote
Old 01-01-2013, 01:00 AM   #12
AREJAY
AREJAY is an unknown quantity at this point
call your local nissan parts dept that can help you with the part. your brake grommet most likey broke. the new grommet will be white and you place it behide your brake pedal. you are welcome
AREJAY is offline   Reply With Quote
Old 01-01-2013, 04:19 PM   #13
fliprayzin240sx
^^^Who the hell buys replacement brake grommets? Stick a bolt and nut in there, dont ever have to worry about it breaking again.
CLICK HERE!!!
Old 01-01-2013, 04:21 PM   #14
yetijeff
yetijeff's Avatar
yetijeff is an unknown quantity at this point
Or a penny and some duct tape
yetijeff is offline   Reply With Quote
Old 01-01-2013, 04:22 PM   #15
yetijeff
yetijeff's Avatar
Oops wrong brake light lol
