Old 01-04-2013, 10:20 AM   #1
Kingtal0n
Kingtal0n's Avatar
95 240sx; New Tie rods, Alignment, and Steering wheel vibrations
Hello!
I have changed tie rods on a 240sx before; however, this is the first time, after I have done it, that the steering wheel is vibrating during a turn. And it vibrates MORE if I make a right turn than a left.
The vibrations seem to be going away the more I drive, so I have a feeling it will dissipate once the cars gets some miles. But that still leaves me wondering...
What causes the steering wheel to vibrate, during a turn, after tie rods have been changed?
My guess would be air, but since I did not mess with the PS lines or fluid res, how can air have gotten in? Unless when you take the inner tie rods off and move the rack by hand something changes.
tinyurl.com/4l80er
Old 01-04-2013, 10:43 AM   #2
awdlv2xlr8
awdlv2xlr8 is an unknown quantity at this point
did you make sure to put the jam nuts on the tierods?
awdlv2xlr8 is offline   Reply With Quote
Old 01-04-2013, 10:45 AM   #3
Kingtal0n
Kingtal0n's Avatar
Do you mean the inner tie rods? are you referring to those large thin plates that keep the inner tie rods from backing out of the rack?
If so, then yes, I put them back in place- but not perfectly. Getting them off the old tie rods I had to bend them up a little bit. So putting them back on they did not look as pretty. But they are in place, nearly solid, holding the tie rod from turning.
that was honestly the hardest part of the job, under the car in the dark trying to get those things lined up.
tinyurl.com/4l80er
Old 01-04-2013, 11:33 AM   #4
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
If you didn't hold the rack&pinion with a wrench and you loosened the tie rod, you most likely destroyed the rack. Same for tightening it down.
Put locking compound on inner thread to rack or use the locking tab.
Double check make sure inner to outer is tight
Check wheel for any other play.
Check tension rod bushings
LCA bushings, when I say check, not just look at it. Get a pry bar and see if it will move around like a worn bushing will move.
Check upper strut hats.
Check rack for leaks and play, check racks bushing.
Check sub-frame/ cross-member bolts.
Check bearings.
Check brakes.
If still have problems, take car to shop.
Hashiriya415 is offline   Reply With Quote
Old 01-04-2013, 12:26 PM   #5
awdlv2xlr8
no, there is one nut that keeps the tie rod from spinning and getting out of alignment, there is ANOTHER nut with an opposite thread pitch that keeps the first nut from backing off.
Old 01-04-2013, 02:43 PM   #6
Kingtal0n
Kingtal0n's Avatar
I dont think mine has a second nut. Theres only a silver nut that holds against the outer tie rod to keep the inner tie rod from rotating (adjusting) by itself.
tinyurl.com/4l80er
Old 01-04-2013, 02:48 PM   #7
Kingtal0n
Kingtal0n's Avatar
Check bearings.
Check brakes.
thank you!
I did try to hold the rack steady while removing/installing.
I used the locking tab, I would have never thought to use thread locker on the rack threads. TC bushings are brand new. The control arm bushings are old and worn but they arnt broken nor have excessive movement.
The struts are OEM and also old and worn, but the shocks are good and the original springs never seem to wear out (lol). I am not sure about the strut hats but thats good you mentioned it I will take a look.
The rack doesnt leak but the lines do (typical 240)
rack bushings are brand new, just installed this a few months ago.
Bearings I cannot see without removing alot of things, I dont know how those are but the spindles are from a S14 with low mileage so they ought to be good.
Subframe and crossmember bolts feel tight, but I dont have a torque wrench just a regular 1/2" drive and under-car bent elbow strength (about 80-100ft/lbs I feel I can apply)
brakes are original from the S14 silvia, still about 30% pad left.
tinyurl.com/4l80er
Old 01-04-2013, 02:50 PM   #8
Kingtal0n
Kingtal0n's Avatar
I think its just the rack fighting to move stiff brand new tie rods. I had someone turn the wheel while i was under the car, and the more I "fought" the steering racks movement the more the steering wheel would start to shake.
does that make sense? Stiff tie rods cause a vibrating rack/steeringwheel?
tinyurl.com/4l80er
Old 01-04-2013, 03:36 PM   #9
Hashiriya415
Trader Rating: (22)
no. it shouldn't vibrate
You don't need to take anything apart to check wheel bearings. You just check the wheel if it moves for bearing play and turn it and listen if you hear abnormal noise from bearings. The wheel should spin very freely, just small drag from brakes.
Old 01-04-2013, 03:54 PM   #10
Hashiriya415
Trader Rating: (22)
Excessive scrub radius? Spacing the wheel too far out.
Maybe your tires are rubbing if you have none OEM size wheels/tires
try different wheels in front
Old 01-04-2013, 04:10 PM   #11
Kingtal0n
Kingtal0n's Avatar
Actually there is something different about the right compared to the left. I wonder if it is the shock.
I just realized this is something it's been doing since before the new tie rods, I just feel it more now with the new tie rods. The car had a slight vibration that got worse when turning right at higher speeds, about 40mph. Does that sound like the shock might be low on gas?
tinyurl.com/4l80er
Old 01-05-2013, 12:21 PM   #12
Kingtal0n
Kingtal0n's Avatar
The lines were causing it. I replaced the soft lines that run from the reservoir to the rack and that solved the issue. thanks guys
tinyurl.com/4l80er
